Optispark vent tube routing, 95 LT1
I have the 2 hoses in what seems to be their natural place but I am struggling to get the pump on and when i get it on, i cant get the third (short) bolt started.
If i go on the outside, it seems like it will interfere with the belt.
Thanks!
It looks like the vent lines run around the outside of the water pump, like i have it. Maybe I will pull the belt tensioner off to open up some space to get the water pump bolts started.
Thank you.
water pump is in, vent hose is routed. I moved the coil out of the way so I had more space to position the water pump while holding the vent tubes off to the side.
It was either move the coil or move the throttle body, either way i needed more room to get the pump, gaskets, and vent tube all in position.
