Need alternator and electrical help, ASAP
Old Feb 2, 2003 | 08:02 PM
hz900's Avatar
hz900
Default Need alternator and electrical help, ASAP
Last night my dist. coil went out on the car. All of a sudden I had no fire to any cylinder. No big deal I just replaced it today with a spare one that I had here from another time. Then I went for a drive and the alternator was showing 11.5 volts. Alright I changed the alternator (still under warranty). Now it is only showing 13-13.5 volts and the positive wire on the back of the alternator is red hot, burnt the hell out of my finger on it. I unhooked the amp from the battery(optima red top) thinking maybe that was the problem, no luck. I can run the car for all of a minute and the wire is red hot, I know this is not right.
I am wondering if the coil had anything to do with it or if it is two different things that happenned at the same time.
Any suggestion on where to start? I traced the wire from the alt. to the battery, or behind the battery rather, and it is not burnt anywhere.
No I don't have an ohm meter, it broke a while back and haven't got a new one.
Thanks guys.
Old Feb 2, 2003 | 08:34 PM
reyderz's Avatar
reyderz
Default Re: Need alternator and electrical help, ASAP (hz900)
Sounds like you got a bunk alternator. Call a shop in the morning and they can tell you.
Old Feb 2, 2003 | 09:56 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
That lead is usually protected by a fusable link located on a connection block below the battery. That wire should not be red hot. I amagine somebody has replaced the fuseable link with a section of wire. This is dangerous and can cause a fire.
It is very unlikey that this problem has anything to do with the alternator.
Personally, I would use a clamp on ammeter and determine the current flow on that wire before driving the car.
It is likely that you have a short or other point of high current usage. You should find this and fix it as I fear that the fuseing in your car has been compromised. This is how fires start.
Old Feb 3, 2003 | 12:48 AM
hz900's Avatar
hz900
Default Re: Need alternator and electrical help, ASAP (PeteL)
Yeah I saw the link. It does appear to be stock along with all the others back there. I am going to have the alt. tested tomorrow on my lunch break. If it checks out I am guessing that I have a major short somewhere where a positive is directly grounding out and causing the problem. If that is the case it is going to be a nightmare to track down.
I am not driving the car because I am afraid of a fire, or at the very least burning the wire in two and leaving me stranded.
I'll post what the results are tomorrow.
Old Feb 3, 2003 | 12:56 AM
jfb's Avatar
jfb
You might have a battery with a shorted cell. If so, the battery terminal voltage will be 10 volts or less instead of 12 to 13 volts when the engine is not running. Your alternator is current limited at its current rating because it is trying to maintain 14.7 volts across a 10 volt battery which causes very high charging current. The fusible link on the alternator should be able to hold up under the alternator maximum current rating, but I would definetely check to see if someone bypassed the fusible link. Measure your battery voltage with the engine off.
Old Feb 4, 2003 | 04:43 PM
1960LS6's Avatar
1960LS6
Make sure you charge the battery. If you fail to do this, the battery is being charged by the alternator. This puts a big strain on the alternator and the wiring. Your alternator could be 105 amps and if the battery is not properly charged, your alternator could be putting out 75-100 amps and the system is not designed to carry that much current for a long time (at least not enough time to recharge a dead battery).
Joe
Old Feb 4, 2003 | 04:49 PM
hz900's Avatar
hz900
I think that I found a wire next to the dist. that might have been rubbing on the air pump pulley after it started working right(long story in another post). I taped it up and put it back in the wire loom where it belonged. So far no problems. Been driving it since last night.
To Need alternator and electrical help, ASAP
