Check those U-joints!
Old Jul 29, 2024 | 12:25 AM
DMITTZ's Avatar
DMITTZ
I should also note that in our C4's the halfshaft u-joints have to support the stress of acceleration, as well as cornering forces. And I suspect turning and accerating is going to create the most stress. And more power, stickier tires and better suspension are proabbably all cumulatively adding to the stress on those u-joints. That's sorta the limitation of the C4 rear architeture I'm referring to, versus a double wishbone design with CV axles really only has to support acceration forces.
Old Jul 29, 2024 | 12:42 AM
DMITTZ's Avatar
DMITTZ
Originally Posted by s346k
any thoughts on using a carbon fiber driveshaft to soak up some of the power and twist rather than transmitting it to the rear dif all at once?
For me the main driveshaft wasn't the issue, although I swapped in chrome moly one with 1350 u-joints (stock were 1310) just as insurance. And so far it has been fine. But you could do a CF main driveshaft if you wanted.
The problem in my case howeverr is the halfshaft u-joints that were failing/ wearing out fast. because the halfshafts also act as the uppper suspension link they need to transmit rotational force (acceleration/deceleration) but also have to withstand compressional and stretching forces from cornering which likely makes CF unsuitable as I believe its only strong in one direction based on how its weaved.
Old Jul 29, 2024 | 04:35 PM
s346k's Avatar
s346k
i was referring to the main driveshaft. essentially cushioning the power fed to the rear dif.
ive read a lot about cf axles. however i have not seen anyone with a c4 post about using them with a failure. all i can remember up to this point is speculation.
Old Jul 30, 2024 | 10:00 PM
dizwiz24's Avatar
dizwiz24
I feel like the stock driveshaft might work well, even on 1000 hp builds with the zf6
simply bc the zf6 doesnt have crazy high gear rations. Like 2.66:1 is nothing crazy
that said, i did put better quality u joints in it (cant remember if 1350 upgrade, but i at least did 1310 cold forged without grease fittings)
now, i did upgrade the rear halfshaft to chromealoy and cold forged u joints also
so im about to find out if the stock driveshaft can take the power on holeshots on 315 MT ET street R drag radials
which it will need to do to send Tesla plaid packing for home on my forged 383 , f1-a94 + 100 shot nitrous build that i am finishing up
Old Jul 30, 2024 | 10:32 PM
DMITTZ's Avatar
DMITTZ
Awesome. I think they will hold, but you might want to change them once or twice a year if your racing as they might wear out.
The gear ratio in my magum trans is 2.97 1st gear and I have 3.54 rear gears.
