Started clutch switch
Old Jul 28, 2024 | 08:34 PM
Frank-in-San-Diego's Avatar
Frank-in-San-Diego
Default Started clutch switch
I have a 1987 Corvette 4+3. It does not start. The power is on, dash lights, VATs is disabled and I think it is the clutch switch
I think this is a purple and green w/ white strip connector that does seem to go down to a switch on the clutch. I put 12V on the Purple and Green/white wires - nothing, I jumped the Purple and Green/white wires - nothing. It does not seem to be the switch
Is there a way to bypass this ? Is there a way to figure out ? What is this?
Old Jul 28, 2024 | 08:57 PM
WVZR-1's Avatar
WVZR-1
Unplug the switch, jumper the wires and then the car should 'CRANK' without the clutch pedal being depressed. If you have the FSM see 8A-30-0.
Old Jul 28, 2024 | 09:37 PM
Frank-in-San-Diego
First - thank you for your help. Appreciated more than you know. I did jumper the purple and green/white wires. Still no start. could it be the starter relay (never touched, probably 1987 vintage. What could prevent the start working??
To Started clutch switch
