I need the optispark vacuum line orifice/filter does anyone know where I can get one or make one? I read on another forum a person melted and flatten one end of a vacuum connector and used a piece of metal wire to poke a hole restricting the flow. Is the orifice .010?
Originally Posted by Bill Jennings
My 95 lt1 opti-spark (new) has a good check valve but the filter is clogged. I've been to all the local cookie-cutter auto stores and even Summit Racing (where I bought the optispark) and Rock Auto to no avail. Even their tech dept guru's don't know what I'm talking about.
I'm down hard and based on the gunk I got out of the old vacuum line, don't dare run it without a filter. Any ideas on where to go for a simple in-line plastic filter???
I used a really small inline gas filter. worked for me.
