Oil Type for 96 LT4
Old Feb 3, 2003 | 05:38 AM
scorned1's Avatar
scorned1
Default Oil Type for 96 LT4
The 96 LT4 CE I am considering purchasing has been run for the first 57,000 with Castrol non-synthetic oil. I plan to use Mobil 1. Don't know why the original owner did not use it. Will this create any problems or could problems have already been created. The engine had no engine noises when I test drove it.
Old Feb 3, 2003 | 07:23 AM
RichS's Avatar
RichS
Default Re: Oil Type for 96 LT4 (scorned1)
5-30 Mobil One.
Old Feb 3, 2003 | 08:51 AM
REW89's Avatar
REW89
Mobil 1. For certain. I switched at 49K when I assumed ownership of my car and never looked back. Bob
Old Feb 3, 2003 | 09:14 AM
6 speed Sid's Avatar
6 speed Sid
Mobile-1. I think 5-30 or 10-30 either one would be fine. Most likely the engine is ok, however it would worry me that non-synthetic had been used since the synthetic handles heat much better and provides less wear. It would have to be a great deal for me to get serious about it. Sid.
Old Feb 3, 2003 | 02:39 PM
scorned1's Avatar
scorned1
Default Re: Oil Type for 96 LT4 (6 speed Sid)
It was bought new by a 66 yr old man. He passed away a year and half ago and left the car to his 19 year old niece. She has driven it since that time. Her father did the oil changes and did not use Mobil 1. From talking to him again, the uncle had all maintenace done by Chevy dealer. So I would assume that the non-synthetic was used only while the niece had the car.
I can get it for $19,500. All it needs is front tires, the rear are new.
Old Feb 3, 2003 | 03:49 PM
jbav1's Avatar
jbav1
Sounds like a nice car. Ditch the dino and go with synthetic, don't worry about it, you should be fine. -Bob
Old Feb 3, 2003 | 04:00 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
5W30 Mobile 1. They don't use oil coolers in the 96's is why they went with the synthetics if I remember correctly. The dino oil won't hold up under the heat load.
Sounds like a good deal.
Old Feb 3, 2003 | 06:12 PM
vader86's Avatar
vader86
It should be fine, not many miles on it.
Do switch to 5w30 Mobil when you get it though.
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
5W 30 Mobil 1 :smash:
Old Feb 3, 2003 | 06:46 PM
scorned1's Avatar
scorned1
Thanks to everyone. I feel more confident now. :cheers:
Old Feb 3, 2003 | 10:47 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: Oil Type for 96 LT4 (Zora)
:withstupid: :auto:
Old Feb 5, 2003 | 08:41 PM
85vetteguy's Avatar
85vetteguy
I would switch to 5-30 mobil 1. Run it for 1000 or so miles and change it again. This will flush the old dino out. Car sounds nice. Good Luck, Guy
Old Feb 6, 2003 | 08:32 AM
LT4BUD's Avatar
LT4BUD
New rear tires only at 19K miles???? LT4's are fun aren't they!!!!!
Love my LT4 and you will love yours too, go for it!!!
[Modified by LT4BUD, 8:44 AM 2/6/2003]
Old Feb 6, 2003 | 09:25 AM
corvette-pilot's Avatar
corvette-pilot
:iagree:
Mobil1 was originally put in to better handle the heat of these engines so it's hard to say what may have happened that just hasn't shown up yet.
Old Feb 6, 2003 | 09:37 AM
silver & red CE's Avatar
silver & red CE
Because most of my Vette's miles are accrued when the temp is above 32*F, I run 10W-30 instead of 5W-30 (Mobile1). The additives used to extend the weight range replace lubricating oil. On my daily driver (Impala SS) I use 5W-30 (in the winter only) because it has to start when the outside temp is as low as -10*F :cry
Eric
To Oil Type for 96 LT4
