One Last Turbo Question[I think]
The reason I am asking is there are many turbo diesel engines at the wreckers, and if I find one that is relatively new and well known, could I just use that?
:cheers:
Just my opnion, but I'd definitely recommend a TO4 based turbo. There are alot more automotive options available, and parts are easily obtainable, interchangeable, and relatively inexpensive.
even the stock buick v6 tubos are cheap and a pair should get you around 850 or more and you can pick them up in good shape cheap. they are a pretty decent turbo and have an integral wastgate.
I might just use a pair of them to check them out. a few TT v6 buicks have been build that made an ez 800 hp with a pair of them.
cya.
When I first started the project last winter, I had just bought a Lincoln 175 Pro Squarwave TIG and wasn't confident yet in my welding skills. Appearance and durability were/are very important to me so I felt at the time that I'd get better results, as well as learn how to do it from an experienced pro.
It's actually very easy, but it can seem intimidating at first. TIG welding stainless steel is relatively easy, patience and rhythm is the key to the "row of coins" appearance. You want your welds to be gold or copper colored, not dark, grey or speckled. It's tempting for a beginning welder to use too much heat/amps. Also, anytime you are welding stainless, you should back-gas the weld or use Solarflux. If you don't, the backside of the weld (the inside of the tubing), will get contaminated from the air and "sugar" up. The result is a weaker weld which would be alot more prone to thermal fatigue and cracking than a proper weld.
Also, when you are making your headers, it's alot easier to ensure a good quality weld around the entire circumference of the tube if you don't weld the primary tube to the cylinder head flange and collector until you are done. After you have the primary's built and tacked, remove the primary tubes from the collector and head flange, weld the primary's on the welding table, back gassing them, then reassemble the primary's back into the flanges and collector and weld them into place.
Good luck!
