transmition
Old Feb 3, 2003 | 11:39 AM
mak567's Avatar
mak567
Default transmition
time for a tranny rebuild, any suggestions on mods and torque converter.car is basically stock just k&n filter.
Old Feb 3, 2003 | 12:22 PM
pablocruise's Avatar
pablocruise
Default Re: transmition (mak567)
plans for the car? Drag racing? Daily driver?
A drain plug in the pan makes for much easier oil changes. Also available are oil coolers and outboard filters. I feel auto tranny life is lenghtened by regular fluid maintenece and cooling. A shift kit will reduce shift overlap which is wear moderate wear occurs. With the kit, ya get more pronounced shifts. Most guys actually like firmer shifts if they drive a Vette tho.
Old Feb 3, 2003 | 03:33 PM
Rick86's Avatar
Rick86
What year tranny?
A good tranny shop will now what updates and mods to perform, but I would at least go with a kevlar band and upgrade the 3-4 clutches with a 9 clutch disk set up. Those cost less than $20.00 and make a big difference.
Old Feb 3, 2003 | 10:08 PM
mak567's Avatar
mak567
Default Re: transmition (Rick86)
the car is an 88 vert. it will be basically a street car i have heard of people using a torque converter out of a s10 can anyone tell me a little about this converter. i would like to put a shift kit for firmer shifts but without the harshness.
[Modified by mak567, 3:10 AM 2/4/2003]
Old Feb 4, 2003 | 03:22 AM
NoWorries's Avatar
NoWorries
I have a Transco shift kit, for the most part its a smooth setup unless you're accelerating quickly.
I think that my torque converter helps it to be smooth, because it shifts below the stall speed.
A torque converter can really wake the car up, stock or non. I went with a 2600 stall, which flash stalls to 2950 rpm in my application. I was told that 2800 rpm stall was the top of the streetable number. Its not. My 2950 is still very streetable, if I had it to do again, I would go 3500 stall. I am not going to change it now, as I want to do a lot more motor work, and 3500 might not be right for some of the big mods I'm planning. But I think a stock car would react nicely to a 3,200 stall converter.
My moms 1995 Blazer S10 flash stalls to 3,200 rpms, so I could see an S-10 converter working well in a Vette. However, I don't know the price on that. I bought a cheap mostly-no-name converter for $208 from the transmission shop that rebuilt my transmission. Its a 12 inch converter, which means its big and heavy and a lot of rotating weight, but for the price it works ok, its not any heavier than stock. Preferably a smaller diameter converter is what you want, but they get pricey quick. Make sure you get a lock-up converter. They're heavier, but they are also the reason Corvettes get 30 mpg.
If you go to a higher stall converter, you are going to need a better transmission cooler than stock. Talk to your transmission shop and see what they recommend for the converter your choose. Bigger is not better if you go too big. Ultimately you should match the cooler to the stall, how its going to be driven, and the climate.
As for clutch packs, a 9-disc pack is a no-no on the street. They are ideal for racing, because of the surface area, but they are so thin that heat effects them. For a street transmission, a good quality 6-disc pack is what you want.
To transmition
