How to setup roller rockers
Old Feb 3, 2003 | 12:41 PM
ninetyfivevette's Avatar
ninetyfivevette
Default How to setup roller rockers
Good morning-
I am about to tighten my roller rockers I got with the hot cam kit and I just wanted to make sure that the below procedure also applies to roller rockers. Any tips or tricks for roller rockers?
Thanks a lot!
Here is a summary of what you do: Get the rotor button pointed at #1 wire on the distributor and then align the line on the vib damper to the TDC pointer on the block. At this point, you adjust both intake and exhaust on #1 cylinder. The GM manual recommends you go to the "zero" lash and then tighten 1 turn of the nut. While in this position, you should also adjust the following: exhaust (3,4 & 8), intake (2,5 & 7). You would then rotate the crank one turn and align the line to the pointer (#6 at TDC) and adjust the following: exhaust (2,5,6 &7), intake (3,4,6 & 8). Please be reminded that just because a cylinger is at TDC, the piston may not be in the firing position. It my by completing the exhaust and starting the intake.
Old Feb 3, 2003 | 12:53 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: How to setup roller rockers (ninetyfivevette)
If you are going to have the exact same rocker arm setup as the LT4 (which I'm assuming you will from the HotCam kit), then you simply torque them to 18 ft-lbs, per the GM service manual, and leave them.
Old Feb 3, 2003 | 01:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: How to setup roller rockers (CorvetteZ51Racer)
The hot cam kit comes with adjustable rockers, do not use this method.
Old Feb 3, 2003 | 01:23 PM
CorvetteZ51Racer
Default Re: How to setup roller rockers (STL94LT1)
Apparently my assumption that the HotCam used LT4 rockers was incorrect. Thanks for clarifying STL94LT1
To How to setup roller rockers
