When to replace knock sensor?
Old Feb 3, 2003 | 02:37 PM
FlyboyZR1's Avatar
FlyboyZR1
Default When to replace knock sensor?
There was a recent thread saying knock sensors degrade over time, but I'm wondering should these be a regular maintenance item? It seems after 16 years it might be time to replace it. Do knock sensor need to be replaced?
:party:
Old Feb 3, 2003 | 06:05 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: When to replace knock sensor? (FlyboyZR1)
first I've heard of it, but the concept would seem to make sense.
Old Feb 3, 2003 | 07:07 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: When to replace knock sensor? (Lone Ranger)
:cheers: First i ever heard of it either! Knock sensor listens for "noise" and retards spark when it senses it. If it malfunctions and erroneously retards spark, I would think you would get a lot of symptoms, just like you would in the old days if you had a retarded spark condition. The fact that it is sitting in a path of coolant, wouldn't cause it to malfunction, IMHO.
It is also curious that in three plus years of following this section closely, this is the FIRST time I have ever seen this. You would think, that if replacing the knock sensor improved performance, MAD and Eck;ers would be all over it :D
They would package a new knock sensor in their existing "20 Hp improvement kits" and Get more big $
I also refuse to believe that you should mix 1 gallon of coolant with 3.5 gallons of water. I have always used distilled water, on that I will agree!
:steering: [ I love that Lil Guy! ]
Old Feb 3, 2003 | 07:43 PM
bogus's Avatar
bogus
Default Re: When to replace knock sensor? (jackdaroofer)
It was my thread that started this discussion... :)
however, the logic that we are using makes an element of sence.
the quartz crystal is under stress inside the sensor, it makes sence that over time, it won't work to optimal efficency.
at some point, the sensor almost has to degrade a small amount. if you're gonna take the time to pull old ones out at 100k miles or more, why not replace them. They ain't all that expensive!
I guess the old axiom that nothing lasts forever applies here.
What is your problem with a 1 gallon of coolant to 3.5 gallons of water?
[Modified by bogus, 7:50 PM 2/3/2003]
Old Feb 3, 2003 | 07:48 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: When to replace knock sensor? (bogus)
Bogus,
How many miles did you have on your car when you replaced your knock sensor?
Old Feb 3, 2003 | 08:36 PM
bogus's Avatar
bogus
I had 106k and change.
Old Feb 3, 2003 | 09:55 PM
dlmeyers's Avatar
dlmeyers
If a marginal O2 sensor is possible, it may not require a leap of faith to suggest a 12-16 year old knock sensor may be on the way out. Oddly enough, just bought one today after spouse heard a "pinging" noise under acceleration (driver has high freq hearing loss). With no other symptoms, 12 year old sensor, $35 for a GM part made in Mexico, not going to hurt. I seldom buy parts without testing first but some situations will motivate me to buy new parts, regardless. Should one buy a used vette, a new O2 and knock sensor may not be a bad investment, along with a fuel filter. Having replaced pistons due to detonation, learned my lesson.
Of course, if codes are set, sensor with bad resistance check, much easier.
dlmeyers 90 coupe zf6 3 speed shocks
To When to replace knock sensor?
