VATS / Fast-Flashing Security Light
In the above diagram, note that the Air Bag fuse goes to Cavity B, then a splice, then back to Cavity C and on to the ECM fuse. The ECM turn-on power does not "go through the DERM". It goes through the DERM's connector, but not the DERM itself. (The intent is probably to prevent the engine from running with the DERM or the AIR BAG fuse removed.)
The reason I didn't mention CRNK A/B is because it has nothing to do with the OP's "won't crank" problem. The CRNK A/B fuse is not associated with the starter solenoid circuit.
The CRNK A/B fuse is an input to the DERM to know that the key is in START. I have no idea why the DERM needs to 'know' that the key is in START, or what the actions are taken by the DERM in START. But the engine will crank and run with the DERM on the bench if cavity B and C are jumpered at the car-side connector.
The SIR system is not associated with the starter circuit. Other than a fuse-protected "tap" on Cir 5 after the Ignition Switch that goes to the feed for fuse CRNK A/B, which then goes to the DERM. (Page 8A-30-0 in my 1990 8A Supplement.) The diagram on this page shows that the SER is controlled by the CCM. Not the DERM.
I'm glad its running.
Cheers.
