Anyone "cut-back" their Rapidfires?
Old Feb 3, 2003 | 04:20 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Anyone "cut-back" their Rapidfires?
I'm not sure how far to cut-back the electrode on the Rapidfires. The center electrode looks like a pyramid, and has a slight taper to it. Anyone got pics? Maybe since people have had luck cutting back regular Delco's, I'll do those instead.
[Modified by FlyboyZR1, 3:34 PM 2/3/2003]
Old Feb 3, 2003 | 09:04 PM
nobodyunknown's Avatar
nobodyunknown
Default Re: Anyone "cut-back" their Rapidfires? (FlyboyZR1)
On regular plugs you cut back to even with the center of the electrode.I did it to my 84 & it has'nt fouled a plug sence.It was fouling every month or so.
Old Feb 3, 2003 | 09:07 PM
scorp508's Avatar
scorp508
I cut mine back and gained an average of 1mph and 0.1 off of my ET.
Old Feb 3, 2003 | 10:12 PM
NoWorries's Avatar
NoWorries
I thought even looking at the Rapidfires cross-eyed was forbidden.
I remember reading that the Rapidfires are absolutely not to be modified, not even regapped. Grinding on them sounds like a bad idea.
I've ground down some Nikon(I think thats their name, Honda plugs) and I'm about to do my AC Delco FR3LS 's tonight for the Vette. You pretty much take the end so that its just about in the middle, and round off the corners really smooth.
I'll try to get some pictures when I do the first one. :seeya
Old Feb 3, 2003 | 10:20 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Anyone "cut-back" their Rapidfires? (NoWorries)
I originally thought you cut it back to the very edge of the center electrode, not to the middle. Check out: http://www.geocities.com/jgkov/CutPlugs.html
HMMMMM......
Old Feb 3, 2003 | 10:25 PM
MrNuke's Avatar
MrNuke
HMMMMM......
Yes you are supposed to only cut them back to the edge of the electrode.
Basically removing the metal that hangs over the elctrode about 1/8th of an inch or slightly less. Cut back too much, and you are screwing with your spark, and if you have a stock or bad ignition you might be worse off, as that would create too large of a gap that you wouldn't want..
Old Feb 3, 2003 | 10:33 PM
scorp508's Avatar
scorp508
Not as long as you remember to re-gap them.
Old Feb 3, 2003 | 10:49 PM
NoWorries's Avatar
NoWorries
I couldn't remember the official name of the electrode, that spark plug picture is about how mine look for the length, although I don't quite go that far, only about to the center.
What I do do, that's not in that picture, is to round off the tip of the electrode nice and smooth...I don't know if it does anything or not, but it makes sense to me not to have any edges. In my mind, you'd get a better spark distribution with a clean tip.
To Anyone "cut-back" their Rapidfires?
