Automatic or stick big difference.
Automatic you can remove the driveshaft release the C beam from tail shaft, remove the forward bolt and loosen the rear bolt move the beam to the side lower transmission a bit remove the Tail shaft extension and you have full access.
Manual You're Screwed I once forgot to put the pin and clip in a 4+3 I had to disassemble all the way back to parts 1&2 the clip & pin and reassemble
