1993 opti spark replacement
Originals, if rebuildable, are a better option than aftermarket, with the exception of Petris (probably)
optisparksolutions@gmail.com
A screeching sound can also be an idler pulley for the serpentine belt. They will make an awful screaming sound when they go bad. So many parts that make screeching sounds when faulty.
For the opti get a Petris. It looks like 93 is sold out, try calling to check when it will be in stock. Advantage is that it direct fitment and vented, attaches to vacuum and intake. It isn't cheap, buy once and cry once. Don't cheap out on aftermarket junk here if you have any plans to keep this car.
If you are swapping the water pump get a Meziere electric pump. This further mitigates the opti issues as the weephole in the original water pump can be plugged.
Take care of all gaskets that are exposed (water pump,throttle body, timing cover, whatever) and also seals for water pump and opti at timing cover.
Like I said, ask the shop what procedure they will follow and what parts they will use if you are not doing it yourself. You don't want to do this twice. I cannot imagine a condition where this isn't a well over 2K job if done correctly with quality parts, the parts above I listed cost a grand. Before you even get a chance to LOOK at a bolt on the opti the following steps will need to occur:
- Remove air intake
- Remove throttle body
- Remove knock sensors (replace these while you are at it)
- Drain all coolant (replace, obviously)
- Remove accessory drive belt (replace if needed)
- Remove idler pulley
- Detach harmonic balancer (can be moved forward, not completely removed, but can be pain)
- Remove water pump (replace thermostat while you are at it)
I told them to pound it because GM put that engine in station wagons, taxis, Firebirds, Camaros etc and we all know Mobil 1 paid them to put that oil cap on, just like my gas cap said BP fuel. As if someone that didn't have a BP within a 100 miles was going to drive that far.
Dealerships will use the name "Corvette" to try and extort more money out of you.
I told them to take us off the offer list that I didn't want anymore of their stuff being sent to me.
