93 Corvette need to update harness please help
Old Aug 29, 2024 | 05:19 PM
Static Smoky's Avatar
Static Smoky
2nd Gear
Default 93 Corvette need to update harness please help
I have a 1993 Corvette and will be undertaking the Torqhead 24x conversion kit to coil near plugs the issue is they do not make the kit for this year dues to some sensor changes can however I can update my harness from a 94+ corvette and make the kit work from there can anyone give me some insight on what I have to do to make the new harness compatible with both the car and the kit?
Old Aug 29, 2024 | 08:26 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
If you can't get that solution to work, the next best solution is the Bailey LTCC, coil on plug conversion.
Old Aug 29, 2024 | 09:16 PM
Static Smoky
2nd Gear
I’ve seen the kit and looked into it’s a good worst case scenario but it still requires the optical switch that the Optispark has and I’m trying to delete the unit as a whole and replace it with an adapter plate and a 1x cam sensor being I’ve already purchased the torqhead kit
To 93 Corvette need to update harness please help
