95 C4 base died now no spark
Old Sep 2, 2024 | 09:01 AM
Wingman's's Avatar
Wingman's
5th Gear
Default 95 C4 base died now no spark
Hey all Im new to owning my C4. I was driving a few weeks ago and the engine just shut off like I turned the key. Then would not start. I got it home found I had no spark so I did the opti with a new coil, plugs, and wires. Still no spark from coil or plugs. I put in a summit racing opti as they had good reviews. I have checked for voltage to the coil I'm getting 4ish volts to the A side. I don't know if I'm missing something.
Old Sep 2, 2024 | 11:00 AM
Torqsplit's Avatar
Torqsplit
Ignition Control Module. Front of the passenger side cylinder head, right above the coil. Pretty inexpensive part, did you happen to change this also?
Old Sep 2, 2024 | 11:02 AM
Torqsplit's Avatar
Torqsplit
They can get a little bit fickle with heat-soak before they die completely. Might run cold then Not when Hot.
Old Sep 2, 2024 | 11:29 AM
Wingman's's Avatar
Wingman's
5th Gear
No I haven't I ordered one. I have seen people talking about jumping it to test if that's the problem but haven't figured out how.
Old Sep 2, 2024 | 12:26 PM
Torqsplit's Avatar
Torqsplit
I'm not familiar with how that is done 🤔 $20~$40 part depending on where you source it tho. Not worth the "electrical adventure" in my opinion 😕 I've "heard" that it does have to be mounted for proper grounding tho. Have to actually bolt on the new one before you try it. Good Luck with it👍
Old Sep 2, 2024 | 01:09 PM
Wingman's's Avatar
Wingman's
5th Gear
Thank you I'll keep the thread updated.
Old Sep 2, 2024 | 09:52 PM
Wingman's's Avatar
Wingman's
5th Gear
Ok so now it's running. However I have a nasty miss fire. I believe it's coming form 7 or 8. In my computer software I can turn off cylinders. I turn off 8 no change, turn off 7 it smoths out. The car is popping out to exhaust. And I can smell raw fuel. I tried checking my plugs and wires. But the engine is hot so I'll do that tomorrow. However could I be out of time on my opti? I put that little pin off the cam in the rectangle shape hole? Just a little bit confused 🤔.
Old Sep 2, 2024 | 11:00 PM
IHBD's Avatar
IHBD
Pro Mechanic
The LT1/4 ICM is not a "$20 part". I've bought 2 Delphis from rockauto in the past 12 months. With tax and shipping they were $165 each.
OP: Check your firing order on the plug wires. Pretty easy to get a couple mixed up, and will cause the problems you are experiencing. Usually one pair like 5&7, 6&8, etc are backwards.
Old Sep 2, 2024 | 11:13 PM
Wingman's's Avatar
Wingman's
5th Gear
Do you have a good way to get to the driver side wires on the opti with out riping off the harmonic balancer?
Old Sep 2, 2024 | 11:20 PM
94WIP's Avatar
94WIP
Default Fuel Control Module!
I would agree. I went through $1,200 in a new opti and other stuff before my trusted mechanic realized it was this $149 part.
Old Sep 3, 2024 | 12:22 AM
IHBD's Avatar
IHBD
Pro Mechanic
If it IS the firing order, it is not likely that the mix-up involves cyls on opposite banks. It's going to be a pair on the opti, or a pair of cyls at the plugs.
The opti plug towers are from top to bottom:
Passenger side: 4 - 6 - 8 - 2.
Driver side: 5 - 3 - 7 - 1
The passenger side isn't too tough to trace the wires, or reach the opti.
The driver side is tight. "Removing the balancer" doesn't get you anywhere for access to the plug wires.
First, I'd consider removing the forward inner wheel housing. Just a few 10mm head bolts. That may give access to see and change the wires. Another strategy may be to remove the belt, idler, and tensioner. Last resort would be to remove the compressor bolts and brackets and lift the compressor up. That shouldn't be necessary. I've seen reports on here that peeps were able to reach the driver side wires from under the car. It's a long reach and a lot of stuff like steering and sway bars is in the path; I've looked, but never tried it.
And the last "Duh" for the next time you R&R an opti: After the opti and plug wires are on, fire it up! Be sure it runs correctly before you continue to put all the other stuff back on and refill the coolant.
Old Sep 3, 2024 | 01:00 PM
rremesal's Avatar
rremesal
Not true. I tested my new ICM while it was hanging from the harness and resting on one of the heater hoses. This is how I personally found out how hot ICMs get...when I grabbed it to disconnect it after running for about 1 minute. Thus, the "grounding" is really only needed to dissipate heat from the ICM to the heat sink via the heat paste in between.
To 95 C4 base died now no spark
