Higher Octane, higher HP?
The burn rate stays the same, but the flame propagates faster with more turbulence, thus burning more endgas at once, thus the fast burn time.
Also, I justr checked my data from my factory original LT-1 Diacom data, 36 degrees with no retard. So it is only a few degrees more
By fixing Tuner A's screwups, you should most definitely gain power. However, even 5 degrees more advance than optimum should cause a net loss in power. FWIW, the pulse-width of the injectors shouldn't affect knock. As far as needing that much timing advance to make max power....it's possible that the port-job on the head reduced the turbulence in the chamber enough that it slowed the burn rate, but it would have to drop it almost 10 degrees in order for MBT to change by 5 degrees. This just doesn't make any sense to me....I still think there's something else going on here...
Heads CNC heads from Florida. Extensive head work, and when you see them you go " nice work", at least the machine shop here did, and they prot and polish heads. Of course, FWIW, I have a slight dish on the psiton.
When the 3.73's are installed, I will be having a new chip burned from a local tuner, who does a number of the MORE Performance chips. We will also have the use of a local dyno to dial it in. All this for the same price that a typical Ed Wright chip costs (around $350)...
Mike
