Superram installed- Now car "cams"
Old Feb 4, 2003 | 03:54 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: (scorp508)
Hey 85superram can you post pics??????
[Modified by FoolCrzy, 3:54 PM 2/4/2003]
Old Feb 4, 2003 | 04:06 PM
1991Z07's Avatar
1991Z07
Default Re: (85superram)
Try this thread first....
http://forums.corvetteforum.com/zerothread?id=481353
Follow the instructions I gave on how to reset the IAC. It is the first thing you should try before tearing into anything....
Good luck Mister Phelps......
[Modified by Joe90, 3:06 PM 2/4/2003]
Old Feb 4, 2003 | 04:30 PM
85superram's Avatar
85superram
Default Re: (Joe90)
No more pics other than sig....I can send u some or just check out my video thread on the cobra race...it has a video
Old Feb 4, 2003 | 04:34 PM
scorp508's Avatar
scorp508
I think he means of the engine.
Old Feb 4, 2003 | 05:56 PM
chucks88's Avatar
chucks88
If you have some pics pertaining to your problem, you can e-mail them to me and I will post them for you
Chuck
[Modified by chucks88, 5:56 PM 2/4/2003]
Old Feb 5, 2003 | 11:46 AM
85superram's Avatar
85superram
Default Re: (chucks88)
I think I figured it out....The big vacuum line that goes into the throttle body has no clamp on it and it is very loose...
Old Feb 5, 2003 | 01:31 PM
FoolCrzy's Avatar
FoolCrzy
could be it...
Old Feb 5, 2003 | 03:41 PM
1991Z07's Avatar
1991Z07
You still need to do the reset procedure for the IAC. I'm guessing that once you tighten the hose and reset, it should idle fine.
Hope it works for you....
[Modified by Joe90, 2:42 PM 2/5/2003]
Old Feb 5, 2003 | 09:21 PM
UDLUV12's Avatar
UDLUV12
Default Re: Superram installed- Now car "cams" (85superram)
Wish I was more familiar with the '85 Vette, but I do have a '86, and had the same problem with my EGR.
Prior to me adding the Mini Ram (which has no requirement for an EGR Valve) I added 4" TALL Center-Bolt Valve Covers a few years back. By doing so, the EGR Pipe would not clear the TALL Covers.
I bought another EGR Valve/Pipe,...made a few measurements...cut both my stock EGR Pipe, and the new EGR Pipe, and then welded them together.
Worked perfectly...got no codes, and smelled no fumes.
