Yet another Optispark question...
Sorry for littering the forum with another Optispark question. I've searched for many hours, and read everything I can find - however, I still have some questions.
I have a 1992 auto convertible. I bought it a couple of years ago, and it's my first Corvette, It has about 90,000 miles on it. To my knowledge, it is nearly original - aside from a replacement ECU and new front ball joints and bushings that I just installed.
While working on the ball joints, I noticed that the plug wires appear to be factory original. I don't know if this car has ever seen a tune-up. I'm thinking that a new set of plugs, wires, cap, and rotor might make sense, while the car is sitting in the garage all winter. However, what should I do about the Optispark?
* Will the 95 "vented" cap and rotor fit on my 92 Optispark? Rock Auto lists a Wells cap for the 92 for about $208, but lists the 95 cap for $95. It seems foolish to spend twice as much for an "inferior" cap, if the newer one is compatible.
* How do I convert my Optispark to a vented design? The way I'm reading some threads, it seems that a vented cap (like the MSD) is all that's necessary. Other threads have described a process of using JB Weld to close off weep holes, and drilling/tapping the Optispark housing for a fitting. What is the correct process, here?
* If I get in there, and find that my Optispark has a sloppy bearing (I think my sensor is fine, as the car still runs well), what should I do about it? It seems that OptiDoctor has closed his practice, and Petris is showing out-of-stock.
* I do not see any label indicating that my car has its Optispark replaced as part of the recall (even though my VIN falls in that range). Does anyone know what the difference was between the original Optispark, and the "upgraded" unit that was installed as part of the recall?
Thanks for any help and advice you can give to me!
* How do I convert my Optispark to a vented design? The way I'm reading some threads, it seems that a vented cap (like the MSD) is all that's necessary. Others threads have described a process of using JB Weld to close off weep holes, and drilling/tapping the Optispark housing for a fitting. What is the correct process, here?
The 95-96 cap and rotor should fit. Petris sells it ( https://petrisenterprises.com/collec...istributor-cap ) for $60.
In my opinion it's best to just get a vented cap and rotor to convert to vented. I think you may still have to seal off the three little holes but I don't recall if those holes are in the housing or cap. If it's the former, you need to seal them, if it's the latter, you don't.
Email brad.
I don't know about any recall, so I can't answer this. But since it's running so well I would imagine if your car got a replacement optispark as part of a recall it still had the Mitsubishi sensor in it, and that is all that matters.
I did hear back from Petris, too. While they are currently out of stock on their Optispark units, they are expecting to have them back in stock within the next couple of weeks.
I only looked into getting an opti off of a junk car because one of the rotor screws on mine broke off while I was removing it due to rust, so I feared it wouldn't be rebuildable. Fortunately he was able to rebuild it, and that was it.
I suppose I assumed that if someone had the time to do the work themselves, they would in turn have the time to hunt for a junk one, but you're right that that isn't necessarily true.
