84-87 Cradle
Old Sep 17, 2024 | 12:31 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Default 84-87 Cradle
I'm considering switching my 1990 Engine-Suspension Cradle to the Early C4 design in my Autocross offseason. So, what do we know about them ? Is the 84 an early design that was improved in the later years ? I I remember correctly the Z-51 Cars have some doubler plates to strengthen them. So, is there any one-year that's better than another? I know somebody who has a complete 84 front suspension I can get. Other than the weird Sway bar ( that I won't be using) Is there any reason I shouldn't use it. Not sure if its a Z-51 or not but I think about 50 percent were. I'm planning on doing some strengthening to it anyway.
Old Sep 17, 2024 | 09:38 AM
WVZR-1's Avatar
WVZR-1
I would think an '87 would be preferred and the '84 regardless of $$$ wouldn't even be considered. If it has the GM part # 14093126 on it I believe you could assume it's the latest version of the early C4 member. A later '86 and any '86 'vert should also have that GM#.
*** You could rule out any with these numbers I'd think: 14050090, 14044544 & 14093108
Old Sep 18, 2024 | 09:29 AM
Gale Banks 80'
It will be a while till I can have a look but now that I have some part numbers, I have something to look for. Just because they think it's an 84 doesn't mean that it is. Thank You.
Old Sep 19, 2024 | 07:49 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just curious, what changes were made to the cradle during the early suspension run?
Old Sep 19, 2024 | 07:54 PM
WVZR-1's Avatar
WVZR-1
Changes to the shock towers, addition of crossmember for Z51 builds and various supports/reinforcements.
Old Sep 19, 2024 | 07:58 PM
skorpion317's Avatar
skorpion317
2024 C4 of the Year Winner - Modified
Old Sep 19, 2024 | 08:06 PM
ThickLizzyVetteswerv's Avatar
The early design uses a massive scrub radius.
https://www.corvetteforum.com/forums...s-numbers.html
Old Sep 20, 2024 | 01:11 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
true. but for autox / racing, front is better. no loss of camber at high steering angle.
https://www.corvetteforum.com/forums...post1601280511
Old Sep 20, 2024 | 10:47 AM
Gale Banks 80'
After watching the Video, it looks as though I might be opening up a can of worms. It looks as though the 86-87 Knuckles will accept my 1990 Wheel Speed Sensors. But will my 13-inch J55 Brake Calipers bolt up to the Knuckles ?
Old Sep 20, 2024 | 10:49 AM
WVZR-1's Avatar
WVZR-1
There are appropriate brackets for the J55 calipers.
Old Sep 20, 2024 | 03:51 PM
Gale Banks 80'
Maybe I can just use my 1990 Knuckles with the early A Arms.
Old Sep 20, 2024 | 05:18 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by gale banks 80'
maybe i can just use my 1990 knuckles with the early a arms.
no !!
Old Sep 21, 2024 | 10:16 AM
ChumpVette's Avatar
ChumpVette
I haven’t seen a set of those brackets in decades. You can probably find somebody to make a set, but it would be easier to just go to the C5 brakes.
I just don’t see the benefit for the average driver doing this swap to get to a Frankenstein setup.
Old Sep 21, 2024 | 10:28 AM
WVZR-1's Avatar
WVZR-1
I just don’t see the benefit for the average driver doing this swss as p to get to a Frankenstein setup.
but ..... if a person was insistent on it then I'd think @76LS1BIRD could provide either brackets. the OP can't use any of his '90 parts, shocks, spring and much other very different.
To 84-87 Cradle
