ZF Trans fluid
Old Sep 29, 2024 | 03:07 PM
agump's Avatar
agump
Default ZF Trans fluid
Thinking of servicing my 89’ ZF.
Any recommendations on brand and spec of gear oil and viscosity ?
Old Sep 29, 2024 | 03:28 PM
C4industries's Avatar
C4industries
I always use Redline MTL full synthetic. It's designed for brass sychros. Shifts great. Never had an issue.
https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
Dave
Old Sep 29, 2024 | 03:29 PM
IHBD's Avatar
IHBD
Pro Mechanic
Pig Snot.
Its a joke from a thread on the ZF lube subject from a few years back. Pig Snot showed up in these threads:
https://www.corvetteforum.com/forums...udreaux-2.html
https://www.corvetteforum.com/forums...ranny-oil.html
Old Sep 30, 2024 | 10:39 AM
RandomTask's Avatar
RandomTask
Pennzoil synchromesh.
Old Sep 30, 2024 | 10:46 AM
WVZR-1's Avatar
WVZR-1
You've owned it how long? This is it's first service? You're 'just thinking'?
Old Sep 30, 2024 | 04:14 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Amsoil Synchromesh is what i use in all my zf’s that i push hard on track.
I didnt know redline mtl worked well. good to know.
Old Sep 30, 2024 | 05:06 PM
pattydaone's Avatar
pattydaone
Castrol TWS 10w-60 is recommended by both zfdoc and ZF. Otherwise, zfdoc recommends any synchromesh fluid (Pennzoil, Amsoil, Valvoline, ACDelco, etc.).
Old Sep 30, 2024 | 06:48 PM
IHBD's Avatar
IHBD
Pro Mechanic
This post has been quoted below. Quoting entire posts is lame, and makes threads difficult to read.
Old Sep 30, 2024 | 06:59 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by IHBD
"TWS" reportedly hasn't been produced for many years. Difficult to use something that isn't available. This quote is from one of the linked threads, from 2019. 5 years ago. Looks like Chump hasn't been able to source TWS since at least 2016. Probably no one else has been able to either.
I keep this oil on the shelf for one of my non-Corvettes. Note the viscosity. When I was researching this oil about a year ago looking for a less expensive way to obtain the same oil ($24.50 per Litre for an oil change that uses 9.5L gets my attention), it seems that it is made by Castrol, there are two formulations for Castrol 10W-60, and that one of them, "TWS" was no longer available. I found it from a Porsche dealer with an online presence for about $85 for a 5L jug. They also have the 1L cans, about $16 each. The metal container with the graphics it comes in probably increases the price too, but is pretty cool to look at on the shelf.
So, another possibility for a "10W-60" motor oil, if that's what you want to run in your transmission. I don't. I put 10W-60 in my air-cooled flat-6. Delco "Syncromesh" goes in my ZF-6.
PIG SNOT in a tin can?
Old Sep 30, 2024 | 07:25 PM
pattydaone's Avatar
pattydaone
Fair enough. I was only able to find the "Edge" formula over the summer and I was too paranoid to use it so I went with Pennzoil. Didn't know it was effectively impossible to source, though. Good to know.
To ZF Trans fluid
