Idle Issue
Old Oct 3, 2024 | 09:23 AM
dcauth14's Avatar
dcauth14
4th Gear
Default Idle Issue
I had to replace the Mass AirFlow Sensor on my 85. Now, when the car is cold the engine idles just fine. As the engine warms up it idles rough and even dies. Really bad in gear. Any thoughts. I have put in a new air filter and cleaned the ports with no luck. Thanks! Dave
Old Oct 3, 2024 | 12:05 PM
drive it's Avatar
drive it
There have been threads on aftermarket MAF sensors that were not calibrated to work with the C4 corvettes. What brand did you buy?
Old Oct 3, 2024 | 06:03 PM
dcauth14's Avatar
dcauth14
4th Gear
I am not sure as the is gone. I am following instructions on how to re-calibrate the sensor.
Old Oct 3, 2024 | 06:08 PM
drive it's Avatar
drive it
I take it that you meant mass airflow sensor. There is no way for you to recalibrate it. It either works well or doesn't. Again some of the aftermarket replacements being sold do not work with C4 Corvettes.
Old Oct 10, 2024 | 06:04 PM
Ekays's Avatar
Ekays
You can try unplugging the battery for ~10 min. I've heard of MAF sensors being replaced but the computer continuing to run off the same adjustments it did with the bad MAF causing poor idle. "Drive it" might be right though, some MAFs just don't work.
Old Oct 11, 2024 | 12:49 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
If you can, put a ohm meter on the IAC and see if it bad..
There are many write ups on them. You wont get a check engine light if it is bad, but it will/can cause idle issues as it isnt moving back and forth controlling the controlled air leak to maintain idle.
Old Oct 23, 2024 | 06:59 PM
dcauth14's Avatar
dcauth14
4th Gear
It turns out that along with the air flow sensor, I ended up EGR valve and the IAC Valve. Problem solved. Car is running great again.
Thanks for the replys.
To Idle Issue
