Gauge fuse keeps blowing
Old Oct 3, 2024 | 05:51 PM
mlm0's Avatar
mlm0
Default Gauge fuse keeps blowing. FOUND THE PROBLEM
It was a short in the wiring that supplies 12 volts to the map reading light on the inside rear view mirror. The mirror was loose enough that the wiring got pinch in the screw that secures the mirror to the windshield
1989 automatic 54000 miles
how do I determine which circuit is causing the fuse to blow. There are several wiring circuits on that fuse. I would like to find a main plug that comes off of that fuse to be able to disconnect each circuit in order to narrow things down. I have a FSM
Old Oct 3, 2024 | 09:31 PM
IHBD's Avatar
IHBD
Pro Mechanic
GAGES fuse circuit is pink/blk.
I'd begin with inspection of the components under the hood that are on that fuse. Inspect the wiring adjacent to, as well as the connectors themselves.
Vapor canister purge solenoid. (Under left headlight.) Air Divert Valve. Air Select Valve. EGR solenoid.
If the fuse blows immediately, the short exists. Try disconnecting as many components as you can. Then plug them back in one at a time until the fuse blows.
Another way to chase short circuits without going through a bag of fuses is to use a light bulb in place of the fuse. For this circuit, use an 1156 bulb with wires soldered to it, put the wires in the fuse slots instead of the fuse. If the bulb is on full-bright, the short exists. If the bulb is off or dim, the short does not exist.
Old Oct 3, 2024 | 11:41 PM
mlm0's Avatar
mlm0
Thanks will try it. Most of smog stuff gone
Old Oct 4, 2024 | 12:09 AM
IHBD's Avatar
IHBD
Pro Mechanic
Fine. But what about the wiring that was left behind? Even more justification to begin with the "smog" wiring. Peel the harnesses open where it is logical that the ends of the wires may be and look for/at any pink/blk wire.
Old Oct 4, 2024 | 02:59 AM
mlm0's Avatar
mlm0
I will check tomorrow and will advise. Thank you for taking the time to assist me
Old Oct 5, 2024 | 03:08 PM
mlm0's Avatar
mlm0
I’m still blowing the fuse. It doesn’t blow right away. If I just idle without driving, the fuse is ok. If I drive a short distance the fuse blows. I’m not sure if movement is causing it or something trying to activate that is causing it. There are so many circuits on that fuse I am stumped on how to narrow it down to the problem circuit. Any suggestions?
Old Oct 5, 2024 | 04:06 PM
mlm0's Avatar
mlm0
Default More information
I was mistaken. It blows the fuse as soon as I turn key to the on position. I just replaced the power seat toggle switch in the console and the ac (c68) face plate. I’m thinking I must have shorted or damaged a wire while doing it. I think taking it apart again is what I’m going to have to do.
Old Oct 5, 2024 | 05:09 PM
mlm0's Avatar
mlm0
Default Found short
Fixed. The wire supplying 12 volts to the map read light on the inside rear view mirror was pinched in the screw that secures the mirror to the windshield
Old Oct 6, 2024 | 09:08 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
that is a heck of a find. was the strategy to use the electrical manual and search for every component that had the pink blk wire to it?
Old Oct 6, 2024 | 02:20 PM
mlm0's Avatar
mlm0
I used FSM. I found the diagram that showed what circuits were using the GAUGE fuse, and started checking the circuits that were easiest to get to. I found it upon checking the 4th circuit which was the mirror map light. I could see the short after I remove the mirror. I got very lucky.
You can’t imagine the smile of relief I had.
Old Oct 6, 2024 | 02:58 PM
VikingTrad3r
Oil Producer
sweet. i can. 😃
To Gauge fuse keeps blowing
