TURBO FOR 84 CROSSFIRE
Old Feb 5, 2003 | 02:35 PM
ink4lfe's Avatar
ink4lfe
Default TURBO FOR 84 CROSSFIRE
AFTER GIVING IT A LOT OF THOUGHT AND SEEING HOW JONAS PUT IN HIS TURBO, I'M THINKING I CAN INSTALL ONE WHERE THE AIR CON COMPRESSOR IS, I JUST NEED FEED BACK IF THIS WILL WORK. :cheers: :U
Old Feb 5, 2003 | 11:03 PM
Phobos84's Avatar
Phobos84
Default Re: TURBO FOR 84 CROSSFIRE (ink4lfe)
Your biggest problem will be making an air box that you can put boost into. One nice thing is sence you are using a wet style injection you can run a little more boost. I saw that on horse power TV but can't remember why. Anyway everything else should be pretty straight forward. I would start by trying to find a new air box. Go to the Crossfire forum and ask arround there. I know some of them have made custom air boxes for superchargers. Shouldn't be too different to make one for turbo.
Old Feb 6, 2003 | 05:33 AM
JoBy's Avatar
JoBy
Actually it is a Vortech V-1 supercharger, but a small turbo would work too. The stock Cross-Fire engine will handle about 10psi boost if it is in good shape and well tuned. That will give you about 300 rwhp. ( 350+ crank hp).
I put the alternator in the A/C pump bracket. It was easy to do.
(click pictures to enlarge)
I cut one ear off the lower alternator bracket and made the supercharger brackets from 10mm thick aluminum.
And this is the air-box:
I will modify the air-box and add an air-water chargecooler to it like this:
I will use a water tank, an electrical water pump and the A/C condensor to cool the water.
Old Feb 6, 2003 | 12:36 PM
Monty's Avatar
Monty
Default Re: TURBO FOR 84 CROSSFIRE (JoBy)
Very clever :cool:
Old Feb 6, 2003 | 05:12 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: TURBO FOR 84 CROSSFIRE (Monty)
Your motor HORRIFYS me Monty! :crazy: :eek: That thing must HAUUL!
Old May 15, 2014 | 05:21 PM
jseremba's Avatar
jseremba
Default turbocharging
I cannot get the pictures to come up. Can you post them. I am thinking of doing this and want to see how you made the air box. Did you et nozzles that can provide more pounds per hour. And did you purchase a new ECM. I saw the EBL tuning site and thought I would need something like that.
Old May 15, 2014 | 05:28 PM
Greg MFn Z's Avatar
Greg MFn Z
St Jude Donor '14
You can't see the pictures because ITS AN ELEVEN YR OLD THREAD.
Old May 15, 2014 | 07:10 PM
sszracing's Avatar
sszracing
Default can we revive these pics
i'm interested in this too..
QUOTE=Greg MFn Z;1586907950]You can't see the pictures because ITS AN ELEVEN YR OLD THREAD.[/QUOTE]
To TURBO FOR 84 CROSSFIRE
