1989 corvettes code 34 and 36
Oct 11, 2024 | 05:00 PM
5th Gear
Hey guys my 1989 corvette is throwing up codes 34 and 36. It’s also having a rough time accelerating. I’m hoping to find out if these issues are related and what could possible reasons be.
Oct 11, 2024 | 05:46 PM
What’s gps does the ecm show the maf is reporting at idle ?
Oct 11, 2024 | 11:01 PM
5th Gear
Quote:
Originally Posted by
Tunedport90
I don’t have a scanner to test that however I did use MAF sensor cleaner and it is running significantly better however not at its best. I’m thinking the MAF sensor might be bad. Additionally it might be worth mentioning that it says my average MPG is 99
Oct 12, 2024 | 11:04 AM
The only time I have seen MPG at 99 is when I've seen an ECM failure. Others can confirm / chime in.
Oct 13, 2024 | 07:56 PM
5th Gear
Yea if anyone can confirm if this is an issue with the ECM or how to troubleshoot ECM that would be awesome
Oct 13, 2024 | 08:04 PM
What does the fsm trouble tree lead towards?
Oct 13, 2024 | 08:36 PM
5th Gear
Tunedport90
I just bought it so I will look into it.
Oct 14, 2024 | 11:35 AM
Follow the FSM procedure, it will likely point to MAF or MAF relays, of which there are 2 behind the battery on the firewall.
If you replace the MAF itself, you should go ahead and replace the relays with it.
Oct 14, 2024 | 11:54 PM
36 should be burnoff relay
