Turn Signal Blinking Slowly
Oct 15, 2024 | 09:36 PM
My right blinker just started blinking very slowly, both front and rear bulbs light up so it's not a burnt out bulb, help.
Thanks.
Oct 15, 2024 | 09:42 PM
Oct 15, 2024 | 10:39 PM
Cruise-In VI Veteran
Have you checked the side marker bulbs as well? There's more than just front and rear bulbs involved
Oct 18, 2024 | 09:18 AM
Quote:
Originally Posted by
Topduarte
Flasher
I have the same problem. But if the flasher is bad why do the left directional and hazards work correctly?
I'm also fairly certain I have a grounding issue because the directional indicators on the dashboard have a dim glow when the directionals aren't on.
Oct 18, 2024 | 06:09 PM
Kilobuck,
Are you running LED bulbs?
Are you running an electronic flasher?
The style with the ground wire?
Oct 19, 2024 | 10:20 PM
If one side is normal, how can the other side being fast, slow, or different be caused by "the flasher"? Same flasher does both sides.
Oct 21, 2024 | 08:42 AM
Usually when one side blinks slower it's because a bulb has burned out, so that would be my first step in diagnosis, like I mentioned in the 3rd post, but we haven't heard any confirmation of that troubleshooting step
Oct 26, 2024 | 09:20 PM
Topduarte
Flasher
Nailed it, it was the flasher, thank-you.
