1993 MEMCAL question
Old Feb 5, 2003 | 07:59 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default 1993 MEMCAL question
I was curious if the 1993 MEMCAL has the limp home chips on it.. the one I just got does not (brand new from GM)
Old Feb 6, 2003 | 04:50 PM
Goody's Avatar
Goody
Default Re: 1993 MEMCAL question (-=Jeff=-)
Mine did. Code on chip was BDBK. You sure you got the right item?
Old Feb 6, 2003 | 06:51 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 1993 MEMCAL question (Goody)
yep BAFL.. 1992-1993 6spd
Guess I need to order another
Old Feb 10, 2003 | 01:26 PM
kittmaster's Avatar
kittmaster
WAIT!!!.......Im doing mine and its bafl 3867 and I have a prom in there and a while gelled surface preped modular IC in the carrier. Mine is also a 6 speed 93. Mine is stock and original so I think you have the right one
kitt
Old Feb 10, 2003 | 02:17 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 1993 MEMCAL question (kittmaster)
kitt
But are there 2 smaller chips under the White Gelled module?
Old Feb 11, 2003 | 01:37 AM
drive it's Avatar
drive it
It's OK....the later speed density has one combined chip....they moved the esc onto the prom also so it does look different.
Old Feb 11, 2003 | 08:58 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 1993 MEMCAL question (drive it)
I think everyone is a bit confused..
For example a MEMCAL for my 89 has an EPROM and 2 limp home mode chips.
my 1991 MEMCAL has an EPROM, 2 limp home mode chips with the ESC circuit mounted just above the Limp Home chips.
the 1993 PROM has an EPROM and the ESC Board no limp home chips. I thought it was bad but I had another one checked and it is the same
Old May 9, 2003 | 11:18 AM
Goody's Avatar
Goody
Guess we should have seen a photo. I've had mine out numerous times now.
Old May 10, 2003 | 08:05 PM
kittmaster's Avatar
kittmaster
Jeff
No there are no chips under it. It just has the white ics. that is the limp home replacement
Kitt
To 1993 MEMCAL question
