Water Pump Installation 530$ yeowww!!
Old Feb 5, 2003 | 08:08 PM
Carlo Ponti's Avatar
Carlo Ponti
Default Water Pump Installation 530$ yeowww!!
$530 is the lowest price i've found so far for the installation of a new water pump in my 1995 corvette. is this right? i'd do it myself, but i don't have the place or the tools to do it, plus i'm pretty bad at this kind of thing.
thanks,
carlo ponti :nopity
Old Feb 5, 2003 | 08:22 PM
91Vette's Avatar
91Vette
Default Re: Water Pump Installation 530$ yeowww!! (Carlo Ponti)
Unfortunately, that doesn't sound too far off. That's why I bit the bullet and changed the water pump on my 91 myself. I took my time and labeled all the stuff I had to remove.
Best of luck to you.
Old Feb 5, 2003 | 08:35 PM
gtsyellow's Avatar
gtsyellow
Default Re: Water Pump Installation 530$ yeowww!! (91Vette)
you do realize you can do this in your garage with simple hand tools in a few hours.
Old Feb 5, 2003 | 08:39 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Water Pump Installation 530$ yeowww!! (gtsyellow)
I paid 100 bucks labor and I supplied the pump. All 4 bolts broke off and it took an air chisel to remove the old pump. It came off in 3 pieces because it galled to the front of the block. I don't think that shop ever wants to see my car again!
Old Feb 5, 2003 | 11:03 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If you are going to go that far you might as well do the optispark while you are at it. They won't charge extra labor since the water pump needs to be removed anyway.
Old Feb 5, 2003 | 11:11 PM
Phobos84's Avatar
Phobos84
Default Re: Water Pump Installation 530$ yeowww!! (Mr Mojo)
Water pumps are very easy. I did mine myself in no time. Took me longer to drain and fill the coolant than it did to change the pump.
To Water Pump Installation 530$ yeowww!!
