HELP car won't shift.
Old Feb 5, 2003 | 09:03 PM
ZAD54's Avatar
ZAD54
Default HELP car won't shift.
Finally got my Camber brace installed today and I was excited to take it out and see if it made a big improvement. Put it in reverse and backed out of the garage and ito the street without any problems. I start to drive off and notice it isn't shifting out of low. Bring it home and notice its alittle low on fluid ( about half a quart). Filled it up but I really didn't think that was the problem. It engages into reverse and forward gears fast but just won't come out of low when its moving. Hopefully this is something silly like the TV cable or something cheap to fix. I'm really not ready for the trans to come out until I get the new cam and torque converter. Got any ideas? :banghead:
Old Feb 5, 2003 | 09:59 PM
nobodyunknown's Avatar
nobodyunknown
Default Re: HELP car won't shift. (ZAD54)
Try disconnecting the battery, clearing the computer.
Old Feb 5, 2003 | 10:34 PM
ZAD54's Avatar
ZAD54
Default Re: HELP car won't shift. (nobodyunknown)
Its an '88, they weren't computer controlled until '93 i think.
Old Feb 5, 2003 | 11:22 PM
FD2BLK's Avatar
FD2BLK
I think you are on the rite track the TV cable will defenitly cause this check that first
Old Feb 6, 2003 | 12:28 AM
ZAD54's Avatar
ZAD54
Default Re: HELP car won't shift. (ejfagala)
Yeah, I was hoping it was something easy ( read: cheap) like the TV cable. I must have got it in a bind or something. Guess I'll have to climb unnderit on my next days off. But if anyone else has any ideas, I'd really like to hear them. :grouphug:
Old Feb 6, 2003 | 09:34 PM
ZAD54's Avatar
ZAD54
Ok, so where are all the transmission guys when I need them? :banghead:
Old Feb 8, 2003 | 06:41 PM
ZAD54's Avatar
ZAD54
TTT :confused:
Old Feb 9, 2003 | 12:13 AM
Probuilt's Avatar
Probuilt
If this happened all at once, then you most likely broke or stripped the governor gear, this happens quite often.
Old Feb 9, 2003 | 05:02 PM
ZAD54's Avatar
ZAD54
Default Re: HELP car won't shift. (Probuilt)
I was running just fine when it went into the garage. The only thing I did was jack up the front to put on the camber brace and when I let it down, it just wouldn't work. Maybe something just came loose underneath. As soon as it warms up some I'll check it out. :seeya
Old Feb 9, 2003 | 06:51 PM
oblivia's Avatar
oblivia
sure sounds like the transmission to me (sorry to say). I don't think the
camber brace could have affected anything... :nonod:
To HELP car won't shift.
