New Electrical Issue Found
Old Oct 26, 2024 | 06:19 PM
Morauske's Avatar
Morauske
Cruising
Default New Electrical Issue Found
Good afternoon gentlemen. I have an interesting issue with my project car. 1985 corvette wont turn off When the key is turned to the off position. The problem occurred after reconnecting the wire that is attached to the positive battery cable. It looks like the previous owner cut the wire because of this issue. When the wire is disconnected from the positive cable the car turns over and shuts off as it should. When the wire is connected, the dash lights up and the car will not shut off, when the key-switch is moved to the off position. Any help would be appreciated.
