A section of my '86 Digital Instrument Cluster is not lighting up. Are there bulbs that can be replaced? If so, how difficult is the removal of the instrument cluster. If not, can someone recommend a repair facility? Thanks for any help.
Re: Digital Instrument Cluster Question? (CG77VETTE)
You can do this yourself, you need 4 Sylvania 882 bulbs.
Remove the plastic bezel covering the unit, this will require removing about 6-7 screws if i remember. Two or three on the face and some more are facing the door on the side. Then wiggle the whole bezel off and youll see 4 silver tabs on the dash unit, twist and remove them. The bulbs are underneath.
You must be careful not to touch the new bulbs when you put them in though, finger oils cause them to get too hot and they blow earlier.
Re: Digital Instrument Cluster Question? (vader86)
Thanks a million for your reply Vader. Does the cluster have to come out or are the bulbs replaced from the front? Also, do you have to remove the headlight **** in order to remove the dash bezel? This sounds like such an easy fix. What do these services do for a few hundred dollars? I guess that is if the display is not visible at all. Mine is visible but it is just not lit in one section near the oil pressure guage and the top of the speedo.
Those services usually replace circuit boards and such inside the cluster.
You don't have to pull the cluster, just do like Vader described. To get the bulbs out and back in, I used a piece of rubber hose that fit snuggly on the bulb, that way you can get it out without breaking it and put the new ones in without touching them directly.
Be careful not to break the bulbs in the sockets. Don't twist the bulbs, they just pull straight out but sometimes over time they can be pretty tight.
They come out from the front, the cluster doesnt need to be removed.
[QUOTE] Also, do you have to remove the headlight **** in order to remove the dash bezel? [/quote}
Yes it pops off, take a good look at it.
They would probably take it apart and resolder things inside so that the lights stay on. Sometimes the circuits come apart with age and need to be resoldered which can cause the same problem you have now. But its best to change the bulbs first and see if that fixes it, it fixed mine.
From: And on the fifth day, subpoenas were served to Obama senior staff
Headlight **** has a spring like retainer behind it that needs to be depressed, away from the dash, then the **** slips right off easy.
You also must remove the tilt handle, it just screws out, normal threads.
The instrument cluster has 4 bulbs, each with a round slip in metalic cover that pulls out.
You have minimal room to use a needle nose plier to get the bulbs out, if they are not stuck from heat. I used a very skinny set of needle nose and had to put tape - inside out - on the blades to grip the bulps. I still broke two, but was able to get the bases out with the small pliers.
Suggest you replace all while you are in there.
I have some 882's I've been trying to give away for a while (I use different in the 89), and have the skinny needle nose pliers. Be happy to help if you get stuck.
It's really not a bad job at all, except what they charge you for the 882's.
Are you saying the 89 doesn't take 882's, or you chose to use something else? When I had mine apart I put in 194's I had laying around. It seems to be working o.k. I found out later that 882's were used stock.
Re: Digital Instrument Cluster Question? (HeeHaw89)
Stock replacements are 882 but I used 194LL also because I already had a bunch of them. The 882 bulb is just a bit brighter. Here's the specs,
