Potential horsepower??
Old Feb 6, 2003 | 04:08 PM
NotSlo's Avatar
NotSlo
Elite Member
Cruise-In III Veteran
St. Jude Donor '09
Default Potential horsepower??
If I stroked my LT4 to 383, ported the heads and intake, bigger TB, and headers, what do you think the RWHP would be?
Old Feb 6, 2003 | 04:10 PM
AS84's Avatar
AS84
Default Re: Potential horsepower?? (NotSlo)
anywhere from 250 to 500. It depends on many many other aspects. Comp ratio, cam, tranny, exhaust, tune, ect ect ect. Can you give us any more info. I know guys with 355's making close to 400 at the wheels.
Old Feb 6, 2003 | 04:13 PM
NotSlo's Avatar
NotSlo
Elite Member
St. Jude Donor '09
Default Re: Potential horsepower?? (AS84)
It's already dynoed around 320 at the wheels with minor mods. For the most part it's a stock LT4.
[Modified by NotSlo, 4:17 PM 2/6/2003]
Old Feb 6, 2003 | 04:42 PM
vader86's Avatar
vader86
with a Hotcam or what other cam?
Old Feb 6, 2003 | 04:55 PM
NotSlo's Avatar
NotSlo
Elite Member
St. Jude Donor '09
Default Re: Potential horsepower?? (vader86)
Not sure I guess. I was thinking about the hotcam. I called an engine shop today and they get approx 2500 to stroke it. I guess that the cam would be based on that. I need to learn more about this so I go in there educated.
Here's the shop I'm looking at http://www.fowlerengines.com/index.htm
Old Feb 6, 2003 | 05:12 PM
vader86's Avatar
vader86
Well a 383+ci engine usually likes a cam with around 220 degrees of duration on both sides, so id say the hotcam would be the minimum cam id run with (218/228).
I dont remember GlockLT4s combo when he had a 383 with Hotcam, you might want to run a couple searches for his old Tech engine threads and read that stuff.
But i would imagine you would be in the 400rwhp range.
Old Feb 6, 2003 | 05:40 PM
NotSlo's Avatar
NotSlo
Elite Member
St. Jude Donor '09
Cool. So that's the bottom end work. With ported heads, ported intake and a bigger TB along with headers, whattya think?
Old Feb 6, 2003 | 06:00 PM
Kehrer923's Avatar
Kehrer923
I have: 383 Lt-1
AFR 195 heads
TPIS ZZ-x cam .558 .558 238 238 112
long tubes
and i havent had a chance to put mine on the dyno but the laptop says it should have around 500
More than anything is getting it tuned right witch i am having trouble with due to my 93 ECM
Old Feb 6, 2003 | 06:27 PM
NotSlo's Avatar
NotSlo
Elite Member
St. Jude Donor '09
Default Re: Potential horsepower?? (Kehrer923)
Nice! That would certainly be plenty of power! Thanks!
I have: 383 Lt-1
AFR 195 heads
long tubes
Old Feb 6, 2003 | 08:03 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
$$$$$$$$$$=HorsePower!!!!!!!!!!!!!!!!
tony
:D :D
Old Feb 6, 2003 | 11:35 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Ok, a few things first...
1) cam lift is determined by a combination of engine displacement, engine speed at peak HP, and head flow.
2) cam duration is determined by a combination of engine displacement and engine speed at peak HP.
3) cam lobe separation angle is chosen to determine the rpm spread between peak TQ and peak HP (there is no real formula for it though)
4) not knowing what cam, what engine speed, what head flow, what intake flow, what exhaust size, what compression ratio, what weight crank, rods, pistons, flywheel, etc makes it impossible to say what kind of power the engine will make. I've worked on 350's that can only flow 205 cfm on the intake side but make 410 flywheel HP. I have also worked on 350's that flow 390 cfm on the intake side and make 850 HP @ 9700 rpm.
I have: 383 Lt-1
AFR 195 heads
long tubes
I would assume this 500 HP estimate from the computer program is flywheel horsepower.
To Potential horsepower??
