defroster relay
Old Feb 6, 2003 | 04:15 PM
jtfrog's Avatar
jtfrog
Default defroster relay
Doe anyone know where the rear defroster relay is on an 86 coupe
Old Feb 6, 2003 | 04:23 PM
jimswhite92's Avatar
jimswhite92
Default Re: defroster relay (jtfrog)
My book says "behind center of dash"
Got a wiring diagram if you need ....
Old Feb 7, 2003 | 06:33 PM
rollervette's Avatar
rollervette
Navigator
I believe it's on the outside of the a/c Programmer mounted above the gas pedal. Remove three screws and unplug light connection on driver's side hush panel look above pedal and you should see it. [IMG][/IMG] :chevy
To defroster relay
