Fuel pressure regulator clogged!
Old Nov 13, 2024 | 05:45 PM
FleetwoodMacEnjoyer's Avatar
FleetwoodMacEnjoyer
3rd Gear
Default Fuel pressure regulator clogged!
Hey guys, I am nearing the (hopefully$ end of my carb swap and after rewiring the fuel pump I went to test out my Holley 12-845 pressure regulator but no fuel is getting through it. I bought it off marketplace a while back and this is my first time using it. Maybe I’m adjusting it incorrectly or it’s set up wrong. I have the factory pump on an 84 vette. The psi is reading 0 and it seems it all going to the return.Also id like to ask does it need to be horizontally level? I’m at work now but I will send pictures
