350 HP while keeping TPI... Is it possible?
Old Nov 17, 2024 | 08:33 PM
Shooterdead's Avatar
Shooterdead
Navigator
Default 350 HP while keeping TPI... Is it possible?
I have an 89 C4 Vette with everything but the brakes stock
Looking to teardown and clean the engine through a shop soon figured I might as well throw in some (debatable) upgrades while I'm at it
I understand this is gonna be a bit of a monster financially, but besides that, I have no idea where to start, even the research escapes me
My buddy who owns a 96 c4 suggested an upgraded Cam along with a valve train for the cam, a full exhaust system with long headers, an aluminum radiator with electric fans, and a smog pump delete.
of course, he also suggested if I wanna go nuts to convert it to a 383 with forged rods, aluminum heads, an intake, and a good tune
Im looking for a HP range of around 350, is this possible with the Tpi?
Budgeting as we go, I have a good amount saved up and can save more as necessary but whats a good ballpark for the cost of the necessary mods?
Please keep the terms simple and expand on abbreviations, not a total noob but as I've said, no clue where to start but would love to learn as much as possible
Old Nov 17, 2024 | 09:45 PM
ULTM8Z's Avatar
ULTM8Z
The older ZZ4 crate engines were making 355 hp and they were essentially L98 engines with a little bit bigger cam and a carb.
So if you get a high flow TPI manifold or something like a Super Ram, a cam with about 212 deg @.050 and a 112 lobe separation angle (LSA), as well as the full length headers, you can easily make 350 hp even with the stock L98 heads.
Old Nov 17, 2024 | 09:55 PM
vader86's Avatar
vader86
You want to keep what exactly? The TPI intake as it is? Because that is the main restriction here, along with the exhaust manifolds.
A lot follows from the answer to that question.
To 350 HP while keeping TPI... Is it possible?
