Old Bilsteins
Old Nov 19, 2024 | 01:58 AM
spaceweasel's Avatar
spaceweasel
Default Old Bilsteins
I have a 35 year old Vette with 43,000 miles.
It has the original Bilsteins with non-Z51.
Has age affected their performance and do they need to be replaced? They feel soft to me, but I have no bouncing or leaks.
What is your experience?
PS:
I forgot to mention. This Vette has been in storage for 23 years and just recently been put back on the road.
Old Nov 19, 2024 | 06:43 AM
Incorvettei's Avatar
Incorvettei
If it were my car I would replace them. As a matter of fact I did that on my 86
Old Nov 19, 2024 | 07:43 AM
hgoodwiniii's Avatar
hgoodwiniii
I have ride control on my car and the front Bilstein's car started making a ton of noise when they wore out.
Old Nov 19, 2024 | 07:50 AM
Vets-Vet's Avatar
Vets-Vet
When I bought my 87 Z52 I replaced them with KYB's plus new wheel bearings etc right away. Once off the car I could see they were not rebounding. They were 35 years old. I am not a race car driver and the KYB shocks have been great so far.
Old Nov 19, 2024 | 10:56 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have seen it both ways.
I have seen bilsteins that were still good after almost 300k miles (check some of the Impala Caprice9C1 forums too)
I have seen bilsteins that were bad after 40k miles on my '95 Corvette. There was some fluid leaking.
So each case is different.
Good luck.
Old Nov 20, 2024 | 03:32 AM
Schieby's Avatar
Schieby
I were in the same situation with my 85 Z51, I replaced them. Do it ! You will be surprised how much better the handling feels.
Bilstein offers a rebuild service for your old ones too.
Old Nov 20, 2024 | 08:46 AM
Vets-Vet's Avatar
Vets-Vet
I tried the Bilstein website and could not find my old shock # 22052460 (stamped on the shock) or the GM p/n for it (22046477 FG3 & FE7 RPO's). All of this was using just the front as an example. I don't know if they will rebuild this old of a shock but other sites that rebuild Bilsteins might. Be ready to bleed after paying the bill.
From what I can see Bilsteins are around 100 bucks a piece new and KYB's are 31. Do you track the car or run it extremely aggressive ??? You may also wish to research Bilstein quality in the past few years.
Old Nov 20, 2024 | 09:17 AM
gtFOOTw's Avatar
gtFOOTw
I just replaced the original Bilsteins on my 96’, they had 80k miles and were shot. Couldn’t tell by looking at them but were very easy to compress when off the car and extended very slowly. Replaced them with KYBs and love them.
Old Nov 21, 2024 | 12:40 PM
Vets-Vet's Avatar
Vets-Vet
I received a return email from bilstein that couldnt answer the question about rebuilding older C4 bilsteins. The gave me the contact info for a private shop that rebuilds bilsteins.
Old Nov 21, 2024 | 01:07 PM
spaceweasel
That's not encouraging.
Old Nov 21, 2024 | 01:40 PM
scudzuki's Avatar
scudzuki
Only tangentially related, the best price I found for the 4 Bilstein B8s for my 2011 Z06 (around $450 shipped) was on rockauto.com. That's pretty much true for everything they sell, though.
Old Nov 21, 2024 | 01:48 PM
89corvettemann's Avatar
89corvettemann
Put KYB on my 89 conv.when i bought it 4 yrs ago. Bilsteins were shot. Handles and rides great. Great shock at a great price. Bought on rockauto.
Old Nov 21, 2024 | 02:00 PM
spaceweasel
I've heard OE Bilsteins are not that great, and there was a post here Bilstein will not rebuild your OEM shocks.
How good are KYB on a C4, and exactly what is the handling like.
I'm not an "original" fanatic and buy what's best. My 110hp 1997 Harley is testimony to that.
Old Nov 21, 2024 | 03:02 PM
spaceweasel
I remember years ago reading that the C4 Bilsteins were valved and tuned especially for the C4.
It's disappointing to discover those exact shocks are no longer available and Bilstein won't rebuild them.
Might just get some KYB s and paint them yellow 😆
Old Nov 21, 2024 | 08:27 PM
typical boomer's Avatar
typical boomer
When I bought my '84 Z51 last July it had KYB that the PO had recently installed. I felt that the rebound of the rear shocks felt too "bouncy" so I Installed new Z51 specific B8 Bilsteins and since the Z51 front shocks aren't available any more I put B6 in the front. Now the rear rebound feels great but the front is a little "floaty" (if that is a word). The PO thinks he has the old OEM's but can't find them. Hearing that a rebuild service may or may not be available is discouraging. I may re-install the front KYB and see if that feels better.
I have read that the Z51 rear shocks had much less compression resistance (jounce?) but much more rebound resistance, due to the stiffness of the spring, which sort of acted like its own shock when it was compressed.
Old Nov 22, 2024 | 03:52 AM
spaceweasel
Originally Posted by typical boomer
When I bought my '84 Z51 last July it had KYB that the PO had recently installed. I felt that the rebound of the rear shocks felt too "bouncy" .
That was the initial problem with my OEM Bilsteins. The rear rebound is too bouncy on tight country roads, making me think the shocks are worn out, not because they have too many miles on them but because they are too old.
Not too excited about $400+ for Bilsteins when I can have KYB Gas-Adjusts for $200.
I will let it sit for the winter and make my decision in the spring.
Old Nov 22, 2024 | 11:45 AM
QCVette's Avatar
QCVette
If the choice is between Bilsteins or KYBs.
My choice is the Bilsteins. I have Bilstein B8s on my '95 and I have KYBs on my '96.
Even with the Z51 shocks on my base '95, the ride is firm, but not harsh. It works very well.
The KYBs on my '96 are much softer. The car rides smoother, but the feel isn't the same. More like a Monte Carlo ride than a sports car.
So the question is what are you looking for with a shock change? If it is better handling and a sports car feel then it is the Bilsteins. If it is a smoother ride, then it is the KYBs.
Good luck.
To Old Bilsteins
Old Nov 22, 2024 | 12:02 PM
spaceweasel
[QUOTE=QCVette;1608359984] I have KYBs on my '96./QUOTE]
Which KYBs? Gas-Adjust or Exel-G?
The Gas-Adjust are supposed to be firmer. That's what I'm looking for but I don't want them to be bone-jarring harsh.
Old Nov 23, 2024 | 11:45 AM
QCVette's Avatar
QCVette
[QUOTE=spaceweasel;1608360037]
I have the car put up for the winter, but I think they are the Gas-Adjust shocks.
Old Nov 25, 2024 | 10:18 AM
spaceweasel
Gas-Adjusts, I presume. Are they stiff enough to give you good handling when the need arises?
