headers: is exhaust a must?
Old Feb 7, 2003 | 12:59 PM
sothpaw2's Avatar
sothpaw2
Default headers: is exhaust a must?
Has anyone ever changed to long tube headers and kept the stock
exhaust? Is keeping the cat back going to negate the gains of the new
headers to zero?
I was thinking that just a cam and headers might be the thing for me.
I don't like the exhaust mod due to resonance and expense.
Old Feb 7, 2003 | 01:14 PM
Nasty C4's Avatar
Nasty C4
Default Re: headers: is exhaust a must? (sothpaw2)
headers without cats and stock exhaust works amazing. quiet at low engine speeds and roars at WOT. :cheers:
Old Feb 7, 2003 | 01:21 PM
vettmanlt4's Avatar
vettmanlt4
Default Re: headers: is exhaust a must? (Nasty C4)
:iagree:
Old Feb 7, 2003 | 01:44 PM
HeeHaw89's Avatar
HeeHaw89
I'm running Hooker 2149's, no precats, gutted main cat and stock LT1 mufflers and it doesn't sound all that intimidating at idle, but when I stomp on it it sounds pretty stout. A good compromise IMO.
Old Feb 7, 2003 | 02:41 PM
vader86's Avatar
vader86
Default Re: headers: is exhaust a must? (HeeHaw89)
The LT1 exhaust isnt as restrictive as the L98s, you will still gain 10-15hp from the longtube headers and it wont be insanely loud with the stock exhaust. Adding a new catback will probably increase your gains to 20hp+ if you got a good one that flows better, but you should pick your catback on sound and not performance. Unless the engine is heavily modified you wouldnt notice much difference performance-wise between any of them.
Old Feb 7, 2003 | 03:07 PM
vetracer's Avatar
vetracer
I was wondering exactly the same thing. I want the headers but not the resonance of aftermarket exhaust. I had a B&B Triflo and didn't like the resonance. I took the brand new $900 B&B off, sold it for $500, and bought a stock '91 y-pipe and mufflers at a salvage yard. The '91 mufflers are larger and less restrictive than '84-'90 mufflers but have the stock sound and no resonance. The '91 exhaust is a direct bolt-on for '86-'90 Corvettes.
sothpaw2's Avatar
sothpaw2
Default Re: clarify
I meant is changing to long tube headers, but keeping the cats (maybe
after market) and stock cat back a reasonable thing?
Thanks Vader, sounds like I have one vote from you.
Old Feb 7, 2003 | 03:57 PM
93 ragtop's Avatar
93 ragtop
Default Re: clarify (sothpaw2)
I think it will work fine. No experience of my own, but I have noticed on the LT1 that most everyone who has posted results have said no performance gain from a cat back system. The stock LT1 exhaust is a very good system to begin with. Let us know how it works out.
Old Feb 7, 2003 | 05:01 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Re: clarify (93 ragtop)
I'm going a different route on my '86.
I have hedman headers, flowmater true-dual cat-back, and sometime in the next month or so I'm replacing the flowmaster mufflers with LT-1 mufflers.
Should I expect to lose any performance from replacing the flows with lt-1 mufflers?
Old Feb 7, 2003 | 05:12 PM
dizwiz24's Avatar
dizwiz24
I concur with the consensus on this thread that long tube headers (minus cats) with a stock LT1 exhaust will give you good gains in HP without the loud sound of an aftermarket exhaust.
This is exactly what I did on my car and it is great. With my car being a convertible, I still wanted to be able to talk to the passenger at 65 MPH on the highway with the top down. Good roar (although some might expect better) at WOT. The extra noise associated with an aftermarket exhaust will just get the cops looking in your direction at least in my town.
I dumped off my cats in the process.
You do have to cut back (I used a hacksaw) the drivers side exhaust pipe, and also have to add an extension pipe (cut to the right length) to both the passenger and drivers side stock exhaust pipes. AFter getting the orientation correct, you weld one end of each extension pipe (Autozone has 3inch id extension pipes) to the stock exhaust, and use exhaust band clamps (Napa has them) to secure the other end to the long tube header collector.
All I know is my next mod is going to be some slicks or something because I cant get any traction in 1st after putting the headers onto my hotcam'd car.
Before the long tube headers, traction wasnt a problem.
Old Feb 7, 2003 | 05:30 PM
sothpaw2's Avatar
sothpaw2
Dizwiz24,
Super! Exactly what I wanted to know! Did you use any cats? If yes,
can you pass emissions?
And did you dyno it or run the 1/4 before/after the headers? From your
sig, sounds like not yet.
...And you did the Hot cam first, correct? I bet the headers make the
car feel faster at low rpm (low torque). Spin'em baby!
To headers: is exhaust a must?
