'94 Steering Column Multi-function Lever repair
Old Dec 7, 2024 | 12:45 PM
sunrise7's Avatar
sunrise7
Default '94 Steering Column Multi-function Lever repair
Anyone have any tips on how to remove and replace this part. My directional signal on and off works but the lever does not turn on and off the headlight brights. When
you pull the lever towards you, there is no clicking sound.
Thanks..
Old Dec 7, 2024 | 04:05 PM
C4industries's Avatar
C4industries
The headlight bright switch is mounted at the base of the steering column near the firewall. There's a metal rod that runs from that lever down to the switch. Whenever I've had issues with the switch not functioning, I've been able to fix it at the area where the metal rod contacts the switch.
