Front AWD hubs?
Old Dec 12, 2024 | 03:53 AM
nimblemotors's Avatar
nimblemotors
Default Front AWD hubs?
I'm planning to use a C4 chassis under a custom hotrod that will be powered by electric motors. I really need it to have awd because you want the braking on the front wheels to do regen back to the battery when you brake for the corners, and then power the rear wheels to accelerate out of them.
What front hubs can be installed relatively easily to give a half shaft in the front wheels?
It looked like it might be possible to put in the rear hubs in the front if I do some drilling and grinding for the 3 stud rears.
But maybe a hub from another car might fit easier?
My search showed some awd corvettes, but they are like full suspension swaps. I won't have a v8 in the way to fit my front electric motor and half shafts.
Old Dec 12, 2024 | 07:49 AM
C409's Avatar
C409
Personally , I would head out to a large Pick n Pull with a tape measure and camera ... Look for hubs that would fit the C4 spindles and also look for complete AWD spindles that would fit the C4 A-arms . Ball joint tapers can be reamed .
Old Dec 12, 2024 | 09:22 AM
s carter's Avatar
s carter
I agree with above your heading down a road not traveled, so just for the reason it's a comparable size vehicle I would measure up S-10 or AWD astro Vans or maybe even take whole spindle if the ball joints and the tie rod point are same.
Old Dec 12, 2024 | 01:49 PM
nimblemotors
Research shows the Chevy S10 uses the same hub front and rear as the rear of the corvette, so looks like I will just make this hub fit into the spindles.
Back in the day when I worked at a parts store, I would spend time looking through our paper catalogs that gave all dimensions to figure out how to do this kind of thing.
Old Dec 12, 2024 | 02:19 PM
TylerScott's Avatar
TylerScott
@nimblemotors Tell me more about these paper catalogs with all dimensions. How can I get my hands on one of those?
Old Dec 12, 2024 | 04:54 PM
s carter's Avatar
s carter
Ok if you work out a bolt up hub bearing that's fine but I believe the spindle/knuckle for a C4 is a Blind hole (not open to the back) so a gaping hole would need to be cut now would that weaken the knuckle
Old Dec 12, 2024 | 06:25 PM
nimblemotors
It's a solid spindle until they added antilock brakes then it has a hole so the tone wheel fits...the hole isn't going to weaken it at all if the hub is inside the hole.
Old Dec 12, 2024 | 07:25 PM
s carter's Avatar
s carter
That's kinda what I suspected but it's been 32 years since I even looked at a hub bearing
Old Dec 13, 2024 | 12:10 AM
ChumpVette's Avatar
ChumpVette
the 91-96 knuckle is an open pass through. The earlier ones were a pocket for the ABS reluctor.
Old Dec 13, 2024 | 12:13 AM
ChumpVette's Avatar
ChumpVette
There are adapters to put C5 C-tracker hubs on the front of C4’s. These are splined. Not sure there is enough room for an axle.
Van Steel was supposed to be making a custom front knuckle that allows the X-tracker Hib to bolt directly up without an adapter. That might give you room.
Old Dec 14, 2024 | 09:18 AM
J.Abbott's Avatar
J.Abbott
You would have an easier job of this with using the C5 Corvette chassis. Not sure if you thought about the front axle yet, but the TBSS had front diff that bolted to the oil pan. Any of the V8 trailblazer's were like this.
Old Dec 30, 2024 | 09:31 PM
nimblemotors
So I have switched to using C5/6/7 suspension components. In fact, the Nissan Leaf I was going to use for another EV project is now going to be used for this 56 Nomad project, it will be the fwd electric motor, I was going to use a smaller front motor, but now it will be a 200hp leaf motor. I may even keep the entire leaf front suspension, not sure yet. But the rear is C5. Was planning two motors, one for each wheel to get torque vectoring, but now I will use the C5 diff and what is unique about it, is the input shaft can be accessible both the front and back, so thinking two motors feeding the C5 diff. Hope it can handle all the gobs of torque from two 200hp motors.
If not, I guess I will go back to one each wheel and get two C5 diffs?
To Front AWD hubs?
