Fuel Pressure Regulator?
Old Dec 16, 2024 | 01:04 PM
ramahon's Avatar
ramahon
Default Fuel Pressure Regulator?
1989, 4speed auto. Fuel pump is 4 years old. RapidFire #5s @.045 torqued to spec. Running 91.
Unknowns:
-Fuel filter is in a PITA location to swap, I have one waiting. Welcome to tips here.
-Unsure on age of fuel injectors.
Fuel Pressure:
Vacuum line off
- Primes to ~25psi (low?)..and slowly drop off. Maybe losing 1-2 PSI/min
- Cranks and runs @ 43 psi
Symptoms:
Cold Start (sitting multiple hours):
- Extended crank. 6-7 seconds on a single crank or multiple shorter cranks. Sputters for a second and then catches.
- Slow to accelerate after transitioning to 2nd/3rd gear.
----Once i've been driving for ~5+ min, this sluggishness goes away...which makes me think fuel vs. spark.
Warm Start (Coolant @ 195+)
- Typically a 2-3 second crank, sputters for a second and then catches.
- No acceleration issues.
Intermittent
- Rough idle. Will surge between 500/900 rpms.
----Hit or miss on this happening when the AC/Heat is on or off....seems to happen occasionally in both scenarios.
Old Dec 16, 2024 | 02:02 PM
ULTM8Z's Avatar
ULTM8Z
Pressure should prime to full pressure and hold there for a long time.
Sounds like you may have a bad regulator.
Old Dec 16, 2024 | 02:36 PM
ramahon's Avatar
ramahon
Thanks for the reply. I have one on order, hoping it is that simple.
Old Dec 16, 2024 | 04:50 PM
ULTM8Z's Avatar
ULTM8Z
Last time I had a bad regulator, it had similar symptoms and was hard starting.
Old Dec 17, 2024 | 06:57 AM
ramahon's Avatar
ramahon
Curious if there are any differing thoughts? Any tests i should run first?
To Fuel Pressure Regulator?
