Help Please
Old Feb 8, 2003 | 06:19 PM
Newtoy's Avatar
Newtoy
Default Help Please
I recall reading a post awhile back about a member with a LT4 who had a vibration in the rear running gear of the car and he described how he replaced everything but the real problem was something simple.
I am in the same boat: It is after the transmission, have balanced all the half shafts and drive shafts, new u-joints, everything in great condition, no unusual wear in the wheel bearing assemblies which are tight with no freeplay.
New tires (25 miles) switched front wheels to back to exclude an out of round wheel.
This vibration occurs at 71 mph to about 80. No matter what gear or rpm. Put it in neutral and coast, the vibration increases so that seems to indicate a drive line problem that is kept partially down by having a load on it. 100% sure it is speed related.
Anyone recall the post I am looking for?
Thanks in advance
Old Feb 8, 2003 | 06:46 PM
bogus's Avatar
bogus
Default Re: Help Please (Newtoy)
that may be a driveshaft...
also, make sure the c-beam is tight. it is under the car, bolted from the tranny to the diff.
