Solid axle C4 “done”
Old Jan 1, 2025 | 02:32 PM
turboC4guy's Avatar
turboC4guy
Originally Posted by ajp01
That is some drag-racer-chassis-builder-level skill man. I am very impressed on multiple levels.
When I was a kid, my uncle who lived two doors down from us did this type of fabrication for his Pro Gas category NHRA car. He fabricated the full frame and did his own engine work. It was like watching a metal artist at work, and watching your ideas and fabrication skills here is a very fond memory of what it takes to engineer a car this way.
Since you mention you'll be driving this on the street as well, the only part of the build that leaves me slightly worried is that plate mount for the Panhard Bar on top of the diff housing. Under cornering load, do you think some triangle plates welded to the mounts would make it stronger so that it won't deflect sideways under ~1G side load at the rear? No issue though for drag racing I think.
Fantastic work!
Thank you! And I’ve thought about that too might go ahead and add a little more on it. Once I finally get it on the ground and can give it some good shakes just to see how it all plays out. Everything there is just theory till I try and drive it. 😂😂
Old Jan 1, 2025 | 02:36 PM
turboC4guy's Avatar
turboC4guy
Originally Posted by C409
Good job ! ... Cool to see an imaginative approach ... When I did my 9" , I wore out a tape measure and much of my brain . LOL ... Not a job for the faint of heart ... BTW , If you don't already have one , I have a short axle for an 8.8 ... If I recall , its around 28" . And , FYI , when I bought my housing and axles from Moser , I also bought their "economy" brake setup which just happened to be '96 Exploder discs and shoes in rotor hat parking brake like the early C4's . It needed the big Ford axle ends .
Now , the fun part ... dialing in the 4-link and shocks at the track .
I have the brakes and mounting form the 1998 explorer I got it from and noticed the similarities with the parking brake set up. I do have axle shafts on the way already! I looked at a lot of your posts for inspiration before I started mine!
Old Jan 2, 2025 | 10:32 AM
Krusty84's Avatar
Krusty84
That looks great!
I have been contemplating this as well. There were some excellent write-ups about modifying the Exploder 8.8s decade(s) ago on the S10 forums. It was the go to budget rear end swap for the drag racers. I don't know what a junkyard 8.8 goes for now, but the S10 guys always picked up two of them so that they ended up with two short side axles to make their one rear end. They used to be really cheap, like $50-$100 each as there were tons of them in the yards back then. Of course, most if not all the S10 8.8 swaps still used leaf springs, so it wasn't nearly as involved as this either.
Good job!
