V2V Frame Stiffeners Road Report
Install was straightforward. Having read prior threads, concern was expressed about weld quality. The brackets i received had the welds ground and polished, so the appearance of the brackets was top notch. As to adjustment, i followed the the instructions that came with the kit, stating in effect to adjust the ride to driver preference. This is how i adjusted the setup - I found the neutral spot for both tensioning rods, i.e., initially able to turn the rod by hand, then using a wrench, gently turning the rod inward, pulling the Heim joints toward each other until i felt resistance. At this point, i turned each rod in one full revolution and decided i was good to go for a road test which revealed 3 behaviors not prior evident when without the stiffeners.
Behavior #1. Immediately upon backing out from the concrete floor to small river rock parking lot surface, on to the road, i noticed the absence of creaking. As i live at the base of the Rocky Mountain foothills, i was looking forward to taking my usual test drive through the curves of the foothills. Coming to the crest of a hill where there's a nasty sharp dip in a turn, there was creaking, but not as much as in the past; i.e., going over that dip in the past, with sustained creaking heard throughout suspension compression/rebound. After this first pass, i stopped for a 2nd adjustment, tightening the rods a second full turn, drove over the dip again, creaking was more brief, actually more of a chirp than a creak, so tightened the rods one more revolution for a total of 3, 3rd pass through the dip, the creak even more brief. Throughout the remainder to the 70 mile ride, sharp turns, road surface irregularities that in the past yielded creaking, besides that nasty dip in a turn, i only had one instance of creaking the entire drive.
Behavior #2. Steering was beyond a doubt more crisp and precise. Understand that i consider myself a world-class skeptic, so for me to notice this change in ride, what i was experiencing, albeit subjective, still was not my imagination nor wishful thinking. By crisp and precise, i mean body roll was limited through the turns, has a controlled feel. Crisp being less roll, my upper body being more with the car in the turn than attention given to keeping myself upright. Precise being more road feel, less flex, feeling more input from the road through the suspension into my butt in the seat. Greater confidence in turns, i.e., feeling secure going 15 to 30 mph faster in turns than posted speed.
Behavior #3. Less wind noise. I can only imagine with less torsional stress on the body, there was less leakage between glass and body surfaces against the different sealing rubber surfaces.
i did not follow the article's instruction for adjusting the tensioner rods. as i mentioned in my writeup, i adjusted the rods as per V2V instructions.
Has anybody removed the convertible X brace and installed this instead or in tandem?
