More unidentified vacuum lines
Old Dec 26, 2024 | 04:16 PM
Brandon Iron Smithe's Avatar
Brandon Iron Smithe
Default More unidentified vacuum lines
Just when I thought I had it figured out, I found these 2 lines that I can’t figure out where they go to. The first is a larger soft hose that looks like it comes through the firewall under the master cylinder. The second is a small rigid nylon line that comes off the T from the charcoal canister. Any help is app
reciated
Old Dec 26, 2024 | 04:23 PM
2011KLR's Avatar
2011KLR
The soft line from under the master cylinder is surely for the cruise control. I believe it comes off of the brake pedal.
That hard line could be one of several possibles - I'm not gonna ponder a guess on it.
Old Dec 26, 2024 | 05:41 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
The brake warning switch is also unplugged, in case you didn't already know, or unplugged it yourself.
At second glance, it looks like the switch itself is broken off on the master cylinder, so I guess that's why it's unplugged.
If I were you, I'd wrap it up and zip tie it and get it tucked away under the ecm or something so it doesn't get wrapped around and destroyed in the steering column.
Old Dec 27, 2024 | 04:38 PM
dburgjohn's Avatar
dburgjohn
going by memory here so may be off. hard line on that side of engine, is that part of air injection system or EGR?
Old Dec 27, 2024 | 06:59 PM
Corvette_Dez's Avatar
Corvette_Dez
This has me a little worried.
Old Dec 28, 2024 | 09:30 AM
WVZR-1's Avatar
WVZR-1
The hard line likely to vacuum tank for cruise? OP - do you have the FSM(Factory/Field Service Manual)?
Old Dec 28, 2024 | 11:54 AM
Corvette_Dez
Originally Posted by WVZR-1
... OP - do you have the FSM(Factory/Field Service Manual)?
And if you don't, you really should buy them ASAP.
Old Dec 28, 2024 | 01:41 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Corvette_Dez
And if you don't, you really should buy them ASAP. Rock auto currently has them.
I have all year C4 + I offer additional with every year C4 FSM that I supply. I believe I'm less expensive or very close to RA and I can deliver same day.
Old Dec 28, 2024 | 01:50 PM
Corvette_Dez
Even better!!!! I didn't know you sold them.
To More unidentified vacuum lines
