84 issues after warm up
Old Jan 11, 2025 | 06:03 PM
Dbailey23's Avatar
Dbailey23
Cruising
Default 84 issues after warm up
My boys have an 84 as a project.
we got it running and now when it warms up the car will miss fire, stall and or lose power, wont get over 2k rpm. Will always restart with a little throttle.
parts we have replaced so far...
fuel pump
Fuel filter
Ignition control mod
Checkd and set the TPS
Injectors
Fuel pressure regulator
Coolent temp sensor
Map sensor
Plugs and wires
Egr valve
Not sure what to look at next... since it only is an isse after the engine warms up im kinda at a loss..
Any ideas or experiences with a similar issue on an 84 or 82 crossfire??
Old Jan 11, 2025 | 07:32 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Wonder if it's related to the CCV purge
Old Jan 12, 2025 | 12:47 PM
ex-x-fire's Avatar
ex-x-fire
Plugged up cat converter.
Old Jan 12, 2025 | 01:23 PM
corvettenorway's Avatar
corvettenorway
firing order..
Old Jan 12, 2025 | 01:46 PM
Difunto's Avatar
Difunto
You could also check that the PROM is correctly connected to the ECM... I've had similar problems with a PROM connected halfway.
Old Jan 12, 2025 | 03:08 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
the culprit id rule out as well.
Oil temps should be sky high, and rpms restricted.
If you use a laser temp gun, you shouldn’t have a massive delta btwn before and after the cat. if you do, exhaust is restricted by the car.
cheapest and quickest way is to carefully remove rear Y, (rusted bolts high propensity of snapping) piece of rebar or similar, mini 2lbs hammer, smash up the plugged honey comb. Suck it out with a shop vac. ductape a piece of smaller hose if you cant get it in.
wear a facemask. if this fixes the issue then u can either run it or replace with a cat.
Old Jan 12, 2025 | 05:16 PM
Dbailey23's Avatar
Dbailey23
Cruising
do you think that would only be an issue or get worse after warm up??
Old Jan 13, 2025 | 06:51 AM
ex-x-fire's Avatar
ex-x-fire
Adding heat can change/expand things. You need to do some testing.
To 84 issues after warm up
