Upgrade to this High Performance C4 Corvette Throttle Performance Switch from SCP!
Old Jan 22, 2025 | 03:22 PM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Default Upgrade to this High Performance C4 Corvette Throttle Performance Switch from SCP!
1984-1991 C4 Corvette Throttle Performance Switch
Available Here: https://www.southerncarparts.com/198...ce-switch.html
This quality reproduction Throttle Performance Switch is built specifically for the 1984-1991 C4 Corvette.When you are looking for the top quality replacement or add on part for your Corvette, look no further. Our Corvette parts are top of the line, simply the best you can buy.
Old Jun 27, 2025 | 10:27 AM
southerncarparts
Supporting Vendor
TPS voltage at Wide-Open-Throttle (WOT) is a function of power enrichment (PE). If the voltage is below a certain point at WOT, the ECM will reduce the level of power enrichment and the engine will not perform to its potential. With the TPS TEC, the TPS voltage is enhanced at 70% throttle, assuring maximum TPS voltage and maximum percentage of PE. This module also corrects for low sensor voltage and "dead spots" in the throttle range. LED indicators verify correct operation.
Old Nov 3, 2025 | 04:03 PM
southerncarparts
Supporting Vendor
Thank you for the orders!
Old Nov 5, 2025 | 09:12 AM
JoBy's Avatar
JoBy
Reproduction? There were no "Throttle Performance Switch" installed those years.
If you what "full throttle", why not just floor it and get the same thing without the "Throttle Performance Switch" ? What is the benefit of this switch?
Old Dec 11, 2025 | 08:27 AM
southerncarparts
Supporting Vendor
The C4 era used Bosch/GM analog TPS & ECM systems where the throttle voltage signal directly affects fuel/timing enrichment behavior. If the TPS voltage at wide-open throttle is below spec, the ECU may reduce “power enrichment” and starve the engine of potential.
Also, over time, cables stretch, sensors wear, or calibrations drift — meaning the ECM might never fully “see” WOT in the traditional sense. This switch addresses that limitation by ensuring the ECM gets the “flag” of WOT earlier. Many C4s are now modified (intakes, camshafts, exhaust, etc) and may benefit from unlocking the higher fuel/timing curves sooner.
My take / recommendation
If you have a 1984-1991 C4 Corvette and you:
Drive it enthusiastically (not just casual cruising)
Want more immediate throttle kick and better high-throttle performance
Don’t have a full aftermarket ECU/tune setup (just stock ECM or mild mods)
Then installing a throttle performance switch is a cost-effective, relatively simple upgrade.
However, if your C4 has a full custom tune or standalone system, you might instead want to look at retuning the ECU directly for best results. Also make sure your TPS cable/sensor and all supporting engine systems are healthy for it to be fully effective.
Old Dec 11, 2025 | 10:42 AM
tequilaboy's Avatar
tequilaboy
In tpi cars, Power Enrichment occurs above 70% tps load axis. This is about 2.7 tps volts.
At what input voltage will this device output 2.7 volts?
Please share the voltage-in to voltage-out transfer function.
Early PE is not really a benefit for a naturally aspirated engine unless excessive fuel consumption is desired.
Old Jan 6, 2026 | 08:22 AM
southerncarparts
Supporting Vendor
Great question. You’re correct on how PE is triggered on TPI cars. This switch does not have a linear voltage-in/voltage-out transfer function and it isn’t programmable. It works by applying a small fixed offset to the TPS signal, which can reference PE earlier relative to throttle position, not at a specific voltage like 2.7V.
Because of that, there isn’t an exact input voltage where the device “outputs” 2.7V, and results can vary slightly between cars. On a naturally aspirated engine, it’s best viewed as a throttle response aid, not a tuning solution. For precise PE control, custom ECM tuning is the better option.
To Upgrade to this High Performance C4 Corvette Throttle Performance Switch from SCP!
