Cam Question?
Old Feb 10, 2003 | 12:18 AM
vetteguy216's Avatar
vetteguy216
Default Cam Question?
I have an '87 auto with the following mods:
Cut airlid
No TB screens
Chambered Exhaust
and soon some longtubes
What would be the best cam to increase performance in my car with my mods.
Keep the fun coming :cheers:
Old Feb 10, 2003 | 12:23 AM
vader86's Avatar
vader86
Default Re: Cam Question? (vetteguy216)
Accel 211 would work.
Old Feb 10, 2003 | 12:26 AM
vetteguy216
Default Re: Cam Question? (vader86)
Do you knw the specs or where I can find them.
How much would this cam cost. :D
Old Feb 10, 2003 | 01:14 AM
vader86's Avatar
vader86
lingenfelter.com
Old Feb 11, 2003 | 05:27 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
I wouldn't try to fit the 211 without machining down the valve guides for clearance. When I took my 87' heads apart, I found that I would have to modify them to fit a ZZ-9 cam, which has less intake lift than a 211.
If you're not going to modify the guides, go for a 216. This will fit without machining the guides.
Good luck :steering:
To Cam Question?
