1985 Spark knock after engine swap
Old Jan 29, 2025 | 06:57 PM
seastman's Avatar
seastman
Default 1985 Spark knock after engine swap
About a year ago I replaced my blown engine with one from a junkyard 85. The replacement engine had the stock intake, runners, etc. but the crank, cam, lifters, pushrods, and rocker arms had been replaced with COMP parts. I did not get a model number off the cam but I measured the valve lift & duration and they measured very close to the stock configuration (I don't remember the exact numbers). Before installing the new engine I replaced the lifters, distributor, spark plugs and wires as well as all the gaskets and head bolts. I also compression tested the block and it held pressure just fine.
The replacement engine idles just fine, usually in the 550-750 range, and cruises smoothly (40-70 mph), but under load (especially when taking off and turning) it has a bad spark knock and struggles to accelerate, very similar to what the FSM describes on page 6E3-70. I have replaced the fuel pump, fuel filter, fuel injectors, and knock sensor but only the fuel pump made a slight difference. Fuel pressure is fine and I have not had any SES codes show up. It's possible the aftermarket cam is too aggressive for the stock tune but I would love to narrow it down before I spend hundreds on a new ECM.
I could really use some help here, this car was a joy to drive before the old engine blew up and now a 5 minute drive feels like a chore.
Old Jan 29, 2025 | 07:24 PM
ex-x-fire's Avatar
ex-x-fire
Do you think the cam might be installed too advanced? Is the EGR system working correctly? Possible carbon build up on pistons.
Old Jan 29, 2025 | 07:40 PM
ULTM8Z's Avatar
ULTM8Z
You're saying you're getting audible detonation?
Possible causes...
Incorrect head gaskets - Didn't the Vette's come with .051 thick head gaskets? If you replaced the gaskets with the more typical .039-.041 thick gaskets, you increased you compression ratio by about 1/4 point.
Too hot of a heat range on the spark plugs
Too much spark advance - recommend re-checking your base spark timing (EST connector disconnected)
ex-x-fire mentioned EGR... the EGR will slow down the rate of combustion, which lowers combustion chamber temps
Incorrect fuel... you're sure you're running the high octane fuel?
I wouldn't think the cam (if it's relatively mild) wouldn't be the cause of this.
Old Jan 29, 2025 | 07:55 PM
seastman's Avatar
seastman
Don't know much about the cam unfortunately. EGR issue is possible but I vacuum-tested the valve before the swap and it worked fine, I also replaced the gasket later on. No EGR codes either. The cylinder walls looked pretty good when I had it apart.
Old Jan 30, 2025 | 12:36 AM
seastman's Avatar
seastman
Originally Posted by ULTM8Z
You're saying you're getting audible detonation? Incorrect head gaskets - Didn't the Vette's come with .051 thick head gaskets? If you replaced the gaskets with the more typical .039-.041 thick gaskets, you increased you compression ratio by about 1/4 point.
The head gaskets came from an engine gasket kit ordered from Rockauto, Fel-Pro I think. I have never heard anything about a specific gasket size for C4s.
Old Jan 30, 2025 | 10:02 AM
ULTM8Z's Avatar
ULTM8Z
Ok so looks like the .051s weren't used until later.
https://www.corvetteforum.com/forums...thickness.html
What heads are you running?
Old Jan 30, 2025 | 03:55 PM
seastman's Avatar
seastman
Thanks for verifying that. They are the stock heads
Old Jan 30, 2025 | 04:33 PM
ULTM8Z's Avatar
ULTM8Z
So your compression may actually be lower than stock... looks like they were running ~.021 gaskets in 1985 according to that link... your felpro kit was probably .039 to .041...
To 1985 Spark knock after engine swap
