Transmission removal
Old Feb 8, 2025 | 04:13 PM
Yonker's Avatar
Yonker
Default Transmission removal
95 Corvette LT1, I have to drop the transmission to replace the torque converter. Now my question is how to remove the catalytic converters. How do you get to the bolts that attach the catalytic converter to the transmission brackets? Is it easier to remove them from above? Or below? I ask because on each side 1 bolt appears easy to get to and the upper bolt impossible to get to... Or am I missing something here. Can the transmission be lowered with the cats attached to the brackets for removal. What's the easiest way. Thank you in advance.
