Coolant leak somewhere???
Old Feb 10, 2003 | 01:06 PM
vvv90's Avatar
vvv90
Default Coolant leak somewhere???
I have a little puddle under the front of the motor after every drive. I'm hoping it's just the waterpump since I plan on changing the Optispark soon anyway. I hear a slight grinding noise too so that's an indicator. However, I still am not abolutely sure.
Don't "they" make some kind of dye I can put in my coolant to see better?
Does anybody know what that is called and where I can get some?
Old Feb 10, 2003 | 01:22 PM
VetBoy89's Avatar
VetBoy89
Default Re: Coolant leak somewhere??? (vvv90)
Look here,
http://www.tracerline.com/lampsandkits_tp-1121.html
Or just do a Google search for "coolant dye"...
:thumbs:
Old Feb 10, 2003 | 03:19 PM
ELEVENS's Avatar
ELEVENS
Your water pump should have a "weep hole" that will dribble coolant if the seal is going south (sorry southerners). If that's dry, I saw the same symptom that went undiagnosed until a cam swap. One of the bolts that hold on the water pump is tapped into the water jacket of the block, and the bolt apparently didn't have enough "goop" on it. That leak drove me nuts! Ok, maybe I was already nuts before then... :skep:
:cheers:
Old Feb 10, 2003 | 04:05 PM
jimswhite92's Avatar
jimswhite92
Dye is available at any auto parts store (NAPA, Auto Zone, Advanced Auto, etc) Need a UV light also to see.
Old Feb 10, 2003 | 06:14 PM
albertlsmith's Avatar
albertlsmith
You may need a flashlight to see below the water pump if it's leaking from the shaft, which happened to me when the bearings wore out. I got my dye at Kragen's, in the a/c refrigerant section. It came in a package of two and they also had a complete kit you can buy for about $70 bucks that included the UV light. Just don't forget to take the sleeve gear thingy off the old waterpump and put it on the new one before you install it! :lol:
Old Feb 10, 2003 | 10:14 PM
Sam Lam's Avatar
Sam Lam
Sears sells an automotive stethscope (spelling???) that is darn good. Put the two ends in your ears and using the long metal probe, put it on the water pump while the mill is turning. If you have bearing going out, it will talk to you! I have used this many times to find noise problems. ;)
To Coolant leak somewhere???
